Archived from groups: alt.comp.periphs.mainboard.asus (
More info?)
FYI - I've been through a few rounds w/ Asus tech support and their
thought is that it's a bad MB and they're going to replace it.
I'll let you know how that turns out.
- Dave
mr wrote:
> Haven't resolved it, but I'm experiencing the exact same problem on a P5GD2
> deluxe. I have had one time, where it actually made the shutdown, in that
> case i configured AI booster to standard just before shutting down. Then I
> removed AI booster and made all the same settings as described by Dave, but
> the problem continues. I haven't tried to reinstall XP yet, it might do the
> trick if I don't install AI booster? Btw, AI booster makes this endless loop
> error message: "-" is not a valid integer... Anyone got a solution for that?
> Regards, Morten
> "Emanuele Baglini" <baglini@NOSPAMgmail.com> wrote in message
> news:2ut4c5F2f05rfU1@uni-berlin.de...
>>Someone have resolved that problem?
>>Best,
>>Emanuele
>>"LeeBos" <leebos@aol.com> ha scritto nel messaggio
>>news:20041025082713.22466.00001425@mb-m06.aol.com...
>>>Mine works fine and is set as follows:
>>>Suspend Mode - Auto
>>>Repost Vodeo on S3 Resume - No
>>>ACPI 2.0 Support - No
>>>ACPI APIC Support - Enabled
>>>Restore on AC Power Loss - Power Off
>>>the rest are all disabled
>>>The only other things I can think of are a noisy power supply or a
>>>defective
>>>motherboard.
>>>>Subject: Re: P5AD2 Premium phantom restart problem
>>>>From: Dave Horoschak dth930@comcast.net
>>>>Date: 10/25/2004 1:15 AM Eastern Standard Time
>>>>Message-id: <puOdnVGLF-xEFuHcRVn-oA@comcast.com>
>>>>Unless there are some in places other than on the APM screen, yes - they
>>>>are all disabled.
>>>> - Dave
>>>>LeeBos wrote:
>>>>>Are ALL of the "Power on by" settings in the BIOS Disabled?
>>>>>>Subject: P5AD2 Premium phantom restart problem
>>>>>>Date: 10/23/2004 2:45 PM Eastern Standard Time
>>>>>>Message-id: <J-ydnb8NmK1cO-fcRVn-pg@comcast.com>
>>>>>>I'm having a problem with a newly installed P5AD2 that restarts itself.
>>>>>>After shutting down WinXP, the system fully powers down (fans off,
>>>>>>etc.) for about 30 seconds and then it starts itself back up. Toggling
>>>>>>the switch on the power supply off-on after it shuts down will keep it
>>>>>>from starting up again.
>>>>>>Per some other suggestions I've seen, I've set the two automatic
>>>>>>overclocking settings to Standard and I've turned off AiBooster, but
>>>>>>neither helped. I'm running firmware 1006.
>>>>>>Enabling and disabling wake on keyboard/mouse doesn't make a
>>>>>>difference.
>>>>>>Has any else seen this before?
>>>>>>Thanks.
>>>>>>- Dave
