Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > PC card connects to wrong AP, help
Forum Wireless Networking : Wireless General Discussions - PC card connects to wrong AP, help
Ok, i finally got my wireless network working (thanks to those who gave advice) but now I have a new problem. I live in an apartment complex and apparently several people around me also have wireless networks. When I get my card to connect to my AP it works for a while but then invariably it detects another available wireless network and disconnects me and then a little windows (XP) pop-up comes up and says that more than one wireless network is available and I have to choose which network to connect to. This causes me to lose my connection and then I have to re-connect. How can I make my laptop only recognize my personal AP (D-link 900+). I have gone into the options and tried to delete the other networks but since they have poor connection (through the walls from other peoples apartments) they tend to lose their connection and then when they are detected again they reappear as new wireless networks and cause me to lose my connection. Please help.
Sponsored Links
Have you tried assigning a static ip to your comp and forcing your router to that ip only? You will probably have to disable DHCP in the router. The ip of your router should be 192.168.0.1, make it unique to something like 192.168.0.123 this should also be the gateway for your pc. I'd assign the pc 192.168.0.2 and subnet 255.255.255.0. I'm not sure what else to do, but this is what I'd try first. You may also need to set the DNS to 192.168.0.123 or whatever your isp's DNS #'s are. Hope that helps.
:tongue: <font color=blue>My job is to polish</font color=blue> <font color=green>turds</font color=green><font color=blue>, I</font color=blue> <font color=red>love</font color=red> <font color=blue>my job.</font color=blue>
Reply to sbolinger2
Static IP's would have zero effect to what AP you associate to. The answer is to assign a specific SSID to your AP and your client card. If your using XP you can sspecify only use a specific Network (SSID) in the XP configuration utility. If your using Win2000 or a previous MS OS you would manage your SSID in the cards driver options.
Reply to kwebb68
I was gonna say, it sounds like you haven't changed anything from the default. Nor has anyone else for that matter. Great security :wink:
<i>It's always the one thing you never suspected.</i>
Reply to jlanka
There are 1152 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
