Archived from groups: microsoft.public.windowsxp.hardware (
More info?)
The first drive should be jumpered as "master" or "master with slave"
assuming it was the old master and jumpered as "master". On some drives
these are the same, on some there is a different setting. The second
should be set to "slave". If the old drive was set to "cable select"
then both should be set th "cable select". If CS is used, look at the
cable. It should have the connectors marked. Most I have seen have a
blue fitting for the end to the motherboard, the boot drive (master) is
on the other end, and the slave goes in the middle. In any case go into
the bios setup and make sure that the slave is set to auto, it may be
set to not installed. I doubt that a 40 gig drive is old enough that it
used LBA or Large with specific parameters.
As far as the two active partitions are concerned (one on each drive),
you can go into fdisk and reset the primary partition on the slave to
inactive but normally it should be ignored by windows. As an aside,
Fat32 which is the format probably installed on the 40 gig from ME or 98
only supports a 32 gig partition. Therefore either it is partitioned or
an overlay is likely installed. If you are using NTFS on the prmiary
drive you may want to convert or reformat the new slave as NTFS all in
one partition.
justme wrote:
> It doesn't matter what's on the slave drive as far as an OS goes and besides
> the bios wouldn't care what if anything is on the drive. Are the drive
> Western Digitals? If so then there are jumpers for single drive (master) or
> dual drives (master or slave). Quite different from, say a Maxtor.
> "Ghoster10" <Ghoster10@discussions.microsoft.com> wrote in message
> news:FD28893A-A202-4921-8F96-3976B70ED6C1@microsoft.com...
>>Well Ive made sure that the salavaged is jumpered as the slave. But its
> still doing the same thing. Could the fact that theyve both got operating
> systems on be a problem. Cause my original has got Xp but the salvaged has
> windows ME. I only have 2 Ports on my Motherboard for Hardware. The 1st is
> used for my DVD dirve & CD Re-Writer and the second is being used for my
> Hard drives.
>>This is really annoying me now!!!
>>"justme" wrote:
>>>If you can't see the drive in the bios then XP won't stand a chance.
> Just
>>>make sure that your boot drive is jumpered as the master and that the
>>>salvaged drive is jumpered as the slave, I suspect that the 2nd drive is
>>>also jumpered as a master and that's why it's not working.
>>>news:839ADA6E-914E-47AF-99AD-A7A4F05D64E2@microsoft.com...
>>>>I have a 40 gigabyte hard drive that came with my Advent PC.
>>>>I have managed to salvage another 40gb hard drive from my friends
>>>computer.
>>>>So I am trying to install it into my PC.
>>>>Everytime I connect The Hard drives to each other my computer wont
> load.
>>>>It says cannot load operating system, but when I plug the master cable
>>>into either hardrive the operating system loads.
>>>>How do I connect them both, so that the original is the master and the
>>>other acts as the slave. When I open the BIOS it wont even detect the
> second
>>>hardrive.
>>>>Please help cause this has been messing me around all week.
>>>>Thanks for any help you can give.
