looking for ideas on how to fix this problem.
while installing 7 H.P. it gets to completing installation then freezes up after computer reboots a warning message appears stating windows 7 has failed to install and resume after reboot, and then the same warning message appears.
I tried the roll back installation option and a message flashes on and off to quickly to read.
and Vista will not come up to start over.
any Ideas on what to Do
try running the upgrade adviser to see if your computer is compatable with windows 7 also upgrading is not best pracitce when using a new OS much better to install from fresh
------------------------------Intel core 2 duo e6750 @ 3.3ghz
Asus P5N32-E PLUS SLi nForce
4gb ocz pc 9200
6 satas
Reply to fowang
