G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Hi
I have PeP4 mobo. It has been fine for about a year.
Now I am overcklocing P4 3.06 processor. It is stable up to 155 FSB @ 1.575V
Core. I can clock it higher but it will get unstable. MBM5 Log tells that V
Core is variating a lot.
I set it to 1.6V:
On idle VCore goes up to 1.66V
Under stress it drops to around 1.56V and every now and then down to 1.52V.
(I assume it crashes when voltage drops too low)
The MoBo Core voltage requlators are not good! If only the Vcore was more
stable around 1.57V I could go up to 160FPB or even higher as cooling is OK.
(Temperature under 50)..
MBM5 log tells allso that PSU is good, all voltages within spec and no
voltage drop at the same time as VCore drop occures.
What to do? I have found several Voltage mods for newer boards, but not for
this particular board. Anoyone know a good site?
BR
Risto
Hi
I set it to 1.6V:
BR
Risto
