Archived from groups: microsoft.public.windowsxp.hardware (
More info?)
Hmm, two more things
First, check your power settings. Click Start-Control Panel-Power
Settings and see if you have the computer set to standby or hibernate
after a period of time or if you have turn off harddisk after a period
of time. Instead, set the setting to Presentation and click OK.
Second, you can try installing the latest version of DirectX (or update
it). www.microsoft.com/directx
Nathan McNulty
anonymous@discussions.microsoft.com wrote:
>>-----Original Message-----
>>Two items.
>>For Brian, it sounds like your chipset drivers or LAN
> card drivers
>>were/are causing the problem. Check with your
> motherboard manufacturer
>>and find out what chipset is on your computer. Make
> sure you have the
>>most recent chipset drivers.
>>For original message, it sounds like you have a video
> card driver
>>problem. Have you tried the latest drivers for your
> video card? Go to
>>www.ati.com or www.nvidia.com or whoever makes your card
> and download
>>the latest drivers. Also, you may have DirectX
> problems, but we'll deal
>> with that if the drivers don't work
>>Nathan McNulty
>>Brian x wrote:
>>>I get the same response whenever i try to access
> internet
>>>radio though windows media player.I recently
> reformatted
>>>after having a lot of problems and before installing
>>>anything else on i tried internet radio and the same
>>>thing happened,I've someone coming to look at the pc
> will
>>>keep you informed of the outcome
>>>>Every time I play a certain game on my pc is reboots
>>>>saying that a device driver caused the problem.
>>>>Any idea how I can find which driver it is and sort it?
>>Updated the driver but it still happens, when it happens
> if you move the mouse/use the keyboard the pc goes to
> start up again the same way it does when it hasn't been
> used for an hour or so but then just powers down again.
