Help. A8V problems with SATA HD, wont boot
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I have recently built an new system which has been running well for the past
fortnight.
Until this morning.
I had been running a 10% overclock with no problems but decided to try my
luck a bit higher.
I changed the overclock mode to manual and tried for 225Mhz on the FSB.
Windows XP Pro booted but reported that it could not find my profile and
allocated me a guest profile instead.
I decided that this degree of overclock was to blame and rebooted to reset
the BIOS back to standard.
Rebooting from there gave a good boot from the BIOS but followed that with a
blank black screen when booting the Operating System.
Everything I have tried so far has got me nowhere. I cannot seem to see the
HD anymore.
How do I get back to recognising the HD?
System is
Athlon 64 3000+ Skt 939 (Winchester)
ASUS A8V Deluxe
WD 160 GB SATA HD
512MB (2 x 256MB) DDR PC4000 RAM
4 answers Last reply
More about help problems sata wont boot
  1. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    "Steve Hennigan" <stephen_hennigan@hotmayle.com> wrote in message news:<%M8md.21378$P7.9359@fe2.news.blueyonder.co.uk>...
    > fortnight.
    > Until this morning.
    > luck a bit higher.
    > HD anymore.
    > System is
    > ASUS A8V Deluxe
    > WD 160 GB SATA HD
    I have managed to get a bit further now:
    I have used the Original XP Pro CD to get to a recovery console and
    fixed the MBR which I assumed was corrupt.
    This allowed me to get as far as the system telling me the the file
    C:\windows\system32\********\system was corrupt. I found a procedure
    on the XP Pro help site to replace this using the original copy from
    the first install.
    The Operating System now boots as far as the Safeboot options screen
    but any menu choice from there on results in a reboot followed by a
    return to the same screen.
    I have considered a repair install of the OS but the XP Pro Cd only
    offers to splat the original OS and settings which means losing a
    large amount of personal files.
    Does anyone have any ideas where I can go from here?
    Steve Hennigan
  2. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    "Steve Hennigan" <stephen_hennigan@hotmail.com> wrote in message
    news:758261d9.0411160158.10fb94a2@posting.google.com...
    [snip]
    > Steve Hennigan
    Looks like the drive got scrambled. Just reinstall from the CD. If it finds
    the previous install (which it should), it will save all the settings and
    drivers and just reinstall like an upgrade. You will have to reapply all the
    windows updates.
    There is no guarantee that any of the other personal files are intact. While
    you are in safe mode, try to copy them off the drive to somewhere safe.
  3. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    > [snip]
    >>Steve Hennigan
    > windows updates.
    Thanks for the advice.
    I have now installed XP Pro into another directory on the same HD.
    This has been quite successful, I have kept access to all the shared
    folderd and all the user accounts except my own.
    I need to access the contents of this in irder to copy over the files
    into my new login name. But all I get is Access Denied.
    All the other users on the old version of XP Pro are accessible so why
    can I not get into my old account?
    Steve Hennigan
  4. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    news:hhxmd.27154$P7.2948@fe2.news.blueyonder.co.uk...
    >> [snip]
    >>>Steve Hennigan
    >> finds the previous install (which it should), it will save all the
    >> settings and drivers and just reinstall like an upgrade. You will have to
    >> reapply all the windows updates.
    >> While you are in safe mode, try to copy them off the drive to somewhere
    >> safe.
    > I need to access the contents of this in irder to copy over the files into
    > All the other users on the old version of XP Pro are accessible so why can
    > Steve Hennigan
    Not sure, it could have been how you configured them. XP Home has the option
    of making the folders private or shared. If they are private, then only the
    owner can access them. Even if you create a new account with the same name
    and password as your last account, it's not the same.
    As administrator, right click the folder, pick Properties and then the
    Security tab. Click the Advanced button, then the Owner tab. Click on the
    Replace owner ... option and click Apply. This should replace the ownership
    of the folder and you should be able to access it.
Asus Overclocking Motherboards
