Operating System Hard drive.
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I recently had so many problems I was advised to reformat
my hard drive. ugh!.
We went ahead but it was a very difficult task I am
running XP Pro and it didn't want to let me do it.
to cut a very long story short we managed to do it but the
operating system appeared on drive F:\ instead of C:\.
It seems that I can change any drive name except the drive
carrying the operating system.
Does anyone know any better? I woud love to return to
normal and have the op sys on C:\
5 answers Last reply
More about operating system hard drive
  1. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    About the only way to get it back to "C" is to re-install XP. This time,
    make sure you don't have anything attached to the computer except the mouse,
    keyboard, and monitor. If you have the drive partitioned, make sure you
    install to the 1st partition. Also, follow the instructions from the
    following link to assure a painless install.
    http://www.michaelstevenstech.com/cleanxpinstall.html
    Thanks to Michael Stevens
    LOL, JAX
    "Sid" <anonymous@discussions.microsoft.com> wrote in message
    news:297c701c464cd$faa46e90$a301280a@phx.gbl...
  2. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Hi Jax,
    vmt for that. As soon as I work up enough courage I will
    give it another go.
    regards
    Sid
    >-----Original Message-----
    XP. This time,
    make sure you
    >LOL, JAX
    message
    reformat
    the
    drive
  3. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    There is a procedure to rename the system drive, but Microsoft doesn't
    recommend it (even though there's an article in the KB).
    http://support.microsoft.com/default.aspx?scid=kb;en-us;223188&Product=winxp
    Mike D.
  4. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Hi Mike,
    I have read that article before. The way I understand it, the warning "Do
    not use the procedure that is described in this article to change a drive on
    a computer where the drive letter has not changed." would apply directly to
    the OP since the letter was assigned at installation of the OS and using
    that procedure would put him at the highest risk of failure. Additionally,
    judging by the information in the post, I doubt that the OP is prepared to
    dive into the registry.
    FWIW, JAX
    "Mike D" <mgdonnelly.not@att.net> wrote in message
    news:u5oQkNQZEHA.3016@tk2msftngp13.phx.gbl...
    > Mike D.
  5. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Just a thought, but you could always try Partition Magic which has the
    ability to rename drives/partitions and fix all links within the OS to
    point to the drive. Only problem is that software costs $$$
    Nathan McNulty
    JAX wrote:
    > Hi Mike,
    > FWIW, JAX
    >>Mike D.
Hard Drives Windows XP
