Tom's Hardware > Forum > Motherboards & Memory > Asus > Help? P4P800 Really slow bootup - a lot of HDD activity be..
Forum Motherboards & Memory : Asus - Help? P4P800 Really slow bootup - a lot of HDD activity be..
Archived from groups: alt.comp.hardware.pc-homebuilt,alt.comp.periphs.mainboard.asus (More info?)
Hi all,
I've been noticing a problem get progressively worst - the time after bootup
which I can start using WinXP. The actual boot up is not that bad, and I
get my desktop quite quickly, however, the HDD activity light is going like
crazy, and I can hear my HDD working overtime for a while before I can
actually use WinXP. I have checked all the usual suspects like
Spy/Ad/wares, or virus and I perform regular mantenances such as disk
defrags on my HDDs. The most noticable jump in time to wait came when I
switched my system HDD to a secondary VIA RAID controller (which isn't being
used as a RAID) - to use my Intel ICH5 controller to control my ATAPI
optical drives (which my VIA controller doesn't support). This was
unfortunately the only way I can get all 3 of my optical drives running at
the same time. I checked that the VIA controller is transferring in UDMA5.
Once everything is running, everything seems fine - just the bootup time.
I am still on WinXP SP1a and my system specs are:
Intel P4 2.4Ghz HT enabled
Asus P4P800 Deluxe (w/2x 512Mb dual channel =1Gb)
Intel IDE:
Primary: Sony DVD-RW (DRU-530A) -master
Secondary: LiteOn CD-RW -master
Secondary: Pioneer DVD-A05 -slave
VIA IDE:
Primary: WD 120Gb (System) -master
Primary: WD 120Gb -slave
Secondary: Quantum 6.4Gb -master
SCSI:
IBM 4Gb HDD
Iomega ZIP removeable
SyQuest 200Mb removeable
ATI Radeon 9000
ATI TV-Wonder
p.s. I heard something a while back that the VIA controller might be the
cause?
Thanks,
Wm
Sponsored Links
indexing is enabled? office fast find installed?
"William Cheng" <wm_cheng_NOSPAM_@sympatico.ca> wrote in message
news:E6rnd.33613$rc.1958820@news20.bellglobal.com...
> Hi all,
after bootup
and I
going like
can
disk
when I
isn't being
ATAPI
running at
UDMA5.
time.
> Intel IDE:
> VIA IDE:
> SCSI:
> IBM 4Gb HDD
> ATI Radeon 9000
> ATI TV-Wonder
be the
> cause?
> Thanks,
> Wm
Reply to jad
On Fri, 19 Nov 2004 13:40:36 -0500 The moonlight laughed on the
blade's edge when "William Cheng" <wm_cheng_NOSPAM_@sympatico.ca>
wrote :
>Hi all,
> Intel IDE:
> VIA IDE:
> SCSI:
> IBM 4Gb HDD
>ATI Radeon 9000
>ATI TV-Wonder
>cause?
>Thanks,
>Wm
Disable file indexing on the drives(Useless option) and also clean out
your Prefetch Folder in the windows folder.
Tips and tricks on here,
http://www25.brinkster.com/chirisoft/speedxp.htm
SpeedXP,
http://www.microsoft.com/windowsxp [...] rtoys.mspx
TweakUI for XP.
Disable unneeded services,
http://www.blackviper.com/WinXP/service411.htm
Disable hibernation unless you really want it also.
Loads more on here,
http://www.winxpfix.com/
http://www.tipsdr.com/
HTH :)
Free Windows/PC help,
http://www.geocities.com/sheppola/trouble.html
remove obvious to reply
email shep@obviouspartyheld.de
Free original songs to download and,"BURN" :O)
http://www.soundclick.com/bands/8/nomessiahsmusic.htm
Reply to Anonymous
>which I can start using WinXP. The actual boot up is not that bad......snip
XP does a trick that gets many people. It shows the desktop long
before the system is done booting up. This is almost certainly what
you are describing. Sure a clean install starts faster since less
things are loading.
Reply to Anonymous
Thanks,
I will try to weed down some of my startup items and run the speedXP - as
well as turn off indexing (how do I turn off indexing?)
Thanks,
Wm
"Shep©" <nospam@nospam.net> wrote in message
news:2uksp0peapsklqp0br4bcojj5rf4kbi7jf@4ax.com...
> wrote :
> >Hi all,
bootup
like
being
at
UDMA5.
> > Intel IDE:
> > VIA IDE:
> > SCSI:
> > IBM 4Gb HDD
> >ATI Radeon 9000
> >ATI TV-Wonder
> >cause?
> >Thanks,
> >Wm
> SpeedXP,
> TweakUI for XP.
> Loads more on here,
> HTH :)
Reply to Anonymous
On Fri, 19 Nov 2004 18:35:17 -0500 The moonlight laughed on the
wrote :
>Thanks,
http://www.tweakxp.com/tweak1335.aspx
Reply to Anonymous
Thanks so much.
That's one down....
news:pr1tp0pdfla728e63nkksds6vt91ndpetq@4ax.com...
> wrote :
> >Thanks,
Reply to Anonymous
> Hi all,
> bootup
> like
> defrags on my HDDs.
> being
> optical drives (which my VIA controller doesn't support).<<<<<<<
> This was unfortunately the only way I can get all 3 of my optical drives
> running at
> UDMA5.
XP is hunting for things that you moved.
Reply to frank
Oh, that makes sense, is there anyway to tell XP where everything is now
manually, instead of having it hunt everytime it loads up?
"Frank" <bbunny@bqik.net> wrote in message
news:4Y7od.58328$6w6.5932@tornado.tampabay.rr.com...
> > Hi all,
> > bootup
I
> > like
> > defrags on my HDDs.
> > being
> > running at
> > UDMA5.
time.
Reply to Anonymous
Its taking me around 1minute 10seconds to load WinXP to get a desktop
But when I get the desktop - the HDD grinds on for another minute before I
can really use WinXP
So total time is around 2:10 or 2:20 for boot up (how does this fair - my
laptop certainly boots up and is usable in 40-50sec)
> Hi all,
bootup
like
being
UDMA5.
> Intel IDE:
> VIA IDE:
> SCSI:
> IBM 4Gb HDD
> ATI Radeon 9000
> ATI TV-Wonder
> cause?
> Thanks,
> Wm
Reply to Anonymous
If no drive letters changed then everything is where it should be.
>>>Hi all,
>>>bootup
> I
>>>like
>>>defrags on my HDDs.
>>>being
>>>running at
>>>UDMA5.
> time.
Reply to Anonymous
news:Cnqod.12291$Ro.611262@news20.bellglobal.com...
I haven't seen any mention of how much RAM you have. If you are short of RAM
it could cause a lot of disk thrashing because of swapping.
Reply to Anonymous
you shep haven't seen you since looking around the elitegroup newsgroup.
i've still got my k7s5a.
Reply to Anonymous
There are 1096 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
