Tom's Hardware > Forum > Windows 7 > Wireless network problem
Hi, I have a strange problem. I installed Windows 7 on my office laptop and it works fine. When I then take my laptop home and connect it to my wireless network at home. I can't surf as expected. What happens is that the laptop connects to the wireless network without problem, however when I start browse the web, i get something like "Website cannot open, check your internet connection" 99 times of 100. But there is no problem with the connection to the wireless network. Any ideas?
Thanks
Sponsored Links
Says it's connected, troubleshooter says there's nothing wrong, but no joy?
First suspect on the list is your Firewall. Disable it, and see. If it works, then you can go back and work on getting it configured for home.
------------------------------ Which Chip? Well, it depends on which set of thieving b@stardz you choose to support: The ones who use insider trading to enrich themselves while running their company into the ground, or the ones who illegally pay vendors to not support the first group.
Reply to Scotteq
There are 566 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
