Archived from groups: microsoft.public.windowsxp.hardware (
More info?)
HP has a tendency to use power supplies that are of a mini
form factor which allows them to use a smaller case. I have
a HP 6465 which had a miniature 115 Watt PS. When I added
some RAM and a second CD-RW drive and hard drive it wasn't
up to the task. I looked for a small form factor PS.
Finally gave up and bought a regular mid-tower case with a
250 Watt PS for $50 (Antec case) and just moved all the
components over. I like the larger case and it wasn't much
different in cost to buying just a power supply, those mini
PS are expensive, because they are not common.
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
"Carey Frisch [MVP]" <mrxp2004@nospamyahoo.com> wrote in
message news:u3xT78qZEHA.3716@TK2MSFTNGP11.phx.gbl...
| You'll have to remove the old power supply and take its
| measurements and determine its form factor. Be absolutely
| sure the new power supply is identical in size.
| Power Supply Form Factors
http://www.pcguide.com/ref/power/sup/form_SFX.htm
| I once purchased the following PS for a HP Pavilion from
Direct.com
| (Enhance SFX-2020 200W Power Supply)
http://www.directron.com/sfx2020.html
| Also see:
| HP cross-reference
http://www.power-on.com/hp.html
| Carey Frisch
| Microsoft MVP
| Windows XP - Shell/User
| Be Smart! Protect your PC!
| http://www.microsoft.com/security/protect/
| "James Hood" <erishood@mts.net> wrote in message:
| news:uxeyLwqZEHA.2972@TK2MSFTNGP12.phx.gbl...
| | hey there;
| | hope some one can help. I have a hp pavilion 3260
desktop. The power
| | supply kicked the bucket. I have APB's out all over the
country, but to no
| | avail. The original was made by bestec. I hope someone
can help as it"s only
| | 5 years old and hardly worth throwing
out...............Jim
