Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
My system contains,
--ASUS "A8V Deluxe" VIA K8T800 Pro Chipset Motherboard For AMD Socket 939
CPU.
--AMD Athlon 64 FX-53, 1MB L2 Cache, Windows Compatible 64-bit Processor 939
Pin.
--ATI RADEON X800 PRO Video Card, 256MB GDDR3, 256-bit, DVI/TV-Out, 8X AGP.
--Cooler Master CM Stacker Full-Tower CASE, Model STC-T01-UW.
When i turn on the PSU i get a green light on the motherboard, no fans or
CPU fan or anything. Then i hit the power switch on my case, and get
nothing. Should i get the CPU fan or PSU fan without hitting the power
button on the front of my case ? Also, the case power switch wire is white
and black, but the connectors on the motherboard are orange and white. The
manual for the motherboard says the connections on the motherboard are color
coded for "foolproof" connecting. But they dont match the wire colors of my
case power switch wire. So i tried connecting the power switch wire anyway,
first black to orange, then white to orange, but the power button seems to
do nothing. I did have hard drives, CD-rom, floppy all hooked up, but i
removed them all except the components listed, to troubleshoot why i get no
POST. Thanks in advance for any ideas.
My system contains,
CPU.
Pin.
