Fax device doesn't work
adrian
223
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Hi,
I don't understand why my fax modem only work once every time I start up
my computer and then it hangs (ie. I can't make another fax call). I got the
following error from event viewer:
Hanging application ntvdm.exe, version 5.1.2600.0, hang module hungapp,
version 0.0.0.0, hang address 0x00000000.
Does anyone know why? BTW: I use Windows XP.
Thanks in advance,
Adrian
billy
173
You were not clear as to the fax software you are using. Check with your hardware manufacturer for a software initialization string. Most fax software has a place to insert the string. This initializes the modem for the fax communication.
"Adrian" wrote:
> Hi,
> Thanks in advance,
> Adrian
