News
Via intros Epia MS Mini-ITX mainboard
Published on June 17, 2004
Via today announced its new Epia MS Mini-ITX mainboard, which comes without the standard I/O back plate to allow small form factor. Read more
ATI Catalyst drivers have a problem
Published on August 27, 2004
ATI has a problem in the latest Catalyst drivers. Read more
Gigabyte intros SLI mainboard
Published on November 22, 2004
Gigabyte follows Asus as one of the first manufacturers to offer a SLI-capable mainboard to run two graphics cards. Read more
Albatron enables use of AGP 8x cards in PCI Express boards
Published on May 17, 2005
Albatron has released a bridge card that allows users in an AGP 8x card in a PCI Express mainboard. Read more
Latest Reviews & Articles
Value In SLI? GTX 260 Core 216 Vs. GTX 280
Published on January 05, 2009
We recently built a $2,500 gaming system with three GTX 260 Core 216 graphics cards, noting that these were less expensive than two GTX 280s. In the performance-value game, is 3-way SLI in the cards? Read more
System Builder Marathon: Performance & Value
Published on January 01, 2009
We’ve built, overclocked, and tested our $625, $1,250, and $2,500 performance machines. How will these three systems compare in overall performance and value? Read more
System Builder Marathon: $2,500 Enthusiast PC
Published on December 31, 2008
We’ve seen how far a moderately priced Core i7 system can take us and now we’re ready to assess the performance advantages of better cooling and a stronger graphics configuration. Will our upgrades be worth the money? Read more
System Builder Marathon: $1,250 Mid-Range PC
Published on December 30, 2008
We see how far $1,250 gets us when building a new Core i7-based system, and how it compares to last month’s similarly priced Core 2 Duo machine. Read more
  Tom's Hardware Forums » Motherboards & Memory » Asus » Problem with a7v8x mainboard and USB 2.0
Word :   Username :
Bottom
Author
 Thread : Problem with a7v8x mainboard and USB 2.0
More Information
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Hi
bought that board when it was new on the market and always used USB
1.1 without ANY problem.
Now I wanted to use a USB 2.0 cardreader, but when I plug it in, Win
XP says that I am trying to use a HighSpeed USB Device on a "standard"
USB Port. It generally works, but transferspeeds show that its not
doing USB 2.0.
I flashed the Bios to the latest non-BetaVersion available. I tried to
update the ViaChipsetdrivers (Also from the asus-Website), but there I
get an error.
First, it demands the file USBUHCI.SYS, which I find as USBUHCI.SY_ on
the Win-INstallation disk. But when choosing this, he tells me, that
this driver fails the windowsXP-Compatibility test.
When I continue, it demands the file from the VIA Driver Disk, but
from a "Win 9x"Driver disk.
I guess there is the problem, but How can I solve it?
Any Ideas?
Need help, please:-)
Mit freundlichem Gruß
Holger Hirschfeld
(Für Mails bitte die "01" aus der Adresse streichen)
(For Mails please remove "01" from mailadress)
Related Product
Profile: stranger
More Information
In article <q9o6r01cavmojsjaeslmvk7r56n5jaql5d@4ax.com>, Holger Hirschfeld
<hirschfeld01@gmx.de> wrote:
> Hi
> doing USB 2.0.
> get an error.
> Any Ideas?
WinXP Service Pack 1 has drivers for USB2. Any USB hardware that
supports EHCI (enhanced) standard will be supported by the Microsoft
drivers. You don't mention whether you have SP1 or not.
AFAIK standalone USB2 drivers (pre-SP1 version) are no longer
available from Microsoft for download. If you are determined not
to use SP1, then you will have to search around to find a copy,
or for that matter, information on how well they work. No commercial
site can carry them without hearing from Microsoft.
Some info on the Via 4-in-1 drivers can be found on an old copy
of the viaarena.com site. Since the viaarena.com site has been
revamped by some web weenie, good info is hard to find.
http://web.archive.org/web/2003021 [...] PageID=211
Notice how USB is not mentioned there. There is an INF driver,
and I believe what that does, is help the OS identify the hardware.
So, if the USB ports are not being enumerated properly, due to
some problem with the INF portion of the 4-in-1 driver, I suppose
that could be a problem.
I do not understand why the installer is looking for USBUHCI.SYS
You can also visit usbman.com, for some advice on USB.
http://www.usbman.com/USB%202%20News.htm
or visit the viaarena site (select topic "usb/1394" from the menu):
http://www.viaarena.com/default.as [...] 13&Search=
but basically, they will all tell you to get SP1 service pack.
Once you have installed SP1, the USB ports still may not be
properly configured. Try this procedure, which is to delete
the USB devices while in Safe Mode, and when the computer is
next booted, the USB stack will be refreshed:
http://www.usbman.com/Guides/Clean [...] 20Mode.htm
I hope your OS in not too messed up now, to make this work.
HTH,
Paul
More Information
hi,
Thanks a lot for that hint. I guess that is the point I have to work
on a bit. (SP1 on the CD i have fails to install properly.)
Greets
Holger
More Information
hi,
Thx again. Manaaged to install SP1, now it works perfectly.
Why is it that without Sp1 there is no USB 2.0 support? Was it not
"implemented" in XP because it was too new?
Holger Hirschfeld
Profile: stranger
More Information
In article <nl6cr05vrh7bcfehft2gam0dtl6gsqs3k0@4ax.com>, Holger Hirschfeld
> hi,
Yes.
It was offered as a separate driver after WinXP was
released. And then Microsoft decided to roll the driver into
SP1, and remove the separate download from their site. The
Microsoft license also specified that the separate driver be
removed from other companies sites as well. Presumably,
this is to get customers to install SP1.
Paul
Google Ads
