Archived from groups: alt.comp.periphs.mainboard.asus (
More info?)
Being new to the 64's I didn't connect the 2x2 ATX12V power connector . I'm
use to just one power connector.
Sorry for the trouble.
Paul I appreciate your help as well as everyone else.
Thanks again
"Paul" <nospam@needed.com> wrote in message
news:nospam-0612042255260001@192.168.1.177...
> In article <XKCdnSyhrZGrlyjcRVn-rA@comcast.com>, "N Alley"
>> news:nospam-0612041946170001@192.168.1.177...
>> > In article <xa2dnb-NLqJNbincRVn-3w@comcast.com>, "N Alley"
>> >> New ASUS KAN-E with AMD 64 30000
>> >> Just put together and when I push and release the power button fans
>> >> stop
>> >> turning and PC won't power on. If I hold the button in fans will turn
>> >> for
>> >> x
>> >> amount of seconds then stop.
>> >> I'm using a new Liteon case with a suncheer 400w ps.
>> >> Any help would be appreciated
>> Thanks for the reply
>> > 1) Check the label on the power supply. Does the +12V have at
>> > least a 15 amp rating ?
>> Yes
>> > When you turn on the PSU, does the green LED light on the motherboard
>> > glow ?
>> Yes
>> > 2) Check that the heatsink is properly installed on the processor.
>> Done
>> 3) Your motherboard has Voice POST (Vocal POST).
>> They are but it doesn't power long enough for it to work
> One other thing I forgot - did you plug in the 2x2 ATX12V power
> connector ? That is needed to power the processor, via
> the Vcore converter. The connector is in the upper left corner
> of the picture of the motherboard in the manual.
> If that was connected, then it is time for the "cardboard" test,
> starting with nothing but the motherboard and the PSU, outside
> the computer case. The motherboard should start even without a
> processor plugged into the socket, and the Voice POST chip has
> its own little processor and firmware, inside the two Voice
> POST chips (the 8 pin DIP IC contains scripts for the processor
> and the compressed sound samples). That is why the Voice POST
> can generate messages, even with a bare motherboard.
> Give that a try. Touch a screwdriver tip to the two Power switch
> pins on the PANEL connector, to start the motherboard. Before
> adding any components, unplug the PSU, or at least make sure the
> green LED on the motherboard is not lit, before changing any hardware
> on the motherboard.
> HTH,
> Paul
