G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I'm hoping somebody can help me with this problem because I think I've
tried everything.
The problem is that when I plug the CPU fan into the CPU_FAN1 socket on
the motherboard, the fan runs at a very high speed and makes a ton of
noise.
Here are the specs for the machine:
-Antec Sonata case w/ 380W PS
-ASUS P5GD1-VM motherboard
-P4 3.2Ghz CPU
-1GB (2X512MB) PC3200 RAM
-LiteOn DVD-ROM
-NEC 16X DVD +/- RW
-Seagate 120GB SATA
-Seagate 200GB SATA
I'm currently using the Cooler Master Hyper48 Silent fan. This fan is
supposed to be silent, but when plugged into the motherboard, it sounds
like a vacuum cleaner. It is anything but silent. When I check the
bios, it reports the fan running at 3400+ RPM. The fan is supposed to
be a 1400RPM fan. It also reports the CPU temp at 42C, which should be
low enough to not cause the fan to be throttled up so high.
If I use one of those adapters that allows you to plug the fan directly
into one of the power leads, then it runs at the advertised 1400RPM.
The problem with this, is that I lose the fan monitoring/throttling
from the mobo, and I also get the annoying beep warning when starting
the computer up.
Here is what I've tried (without success) to fix this problem:
-Swapped out the motherboard for another P5GD1-VM
-Tried a different fan. A Thermaltake. Same fan speed in BIOS
-Tried a different CPU.
-Tried enabling/disabling Q-Fan in the BIOS
-Flashed the bios to the latest version: 1007
-Made sure the FANPWR1 jumper was set to PWM (also tried DC just for
kicks)
-Verified that I am plugged into the CPU_FAN1 socket NOT the CHA_FAN1
socket
-Appropriately applied thermal grease to the CPU (not too much/not too
little)
Any help/advice anyone can supply would be greatly appreciated. As I
said, it runs at a normal speed when plugged into a power lead via an
adapter, but that is a work-around, and not a solution that I want to
use long-term. The CPU runs at 48-49C when plugged in with that lead,
but I really want to have the mobo monitoring that fan.
Thanks,
Indy
tried everything.
noise.
-P4 3.2Ghz CPU
-LiteOn DVD-ROM
-NEC 16X DVD +/- RW
-Seagate 120GB SATA
-Seagate 200GB SATA
the computer up.
kicks)
socket
little)
Thanks,
Indy
