Tom's Hardware > Forum > Motherboards & Memory > Asus > Blue screen problem
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Hi,
I have an Asus A7N8X - E Deluxe M/B running an AMD Athlon XP 3000+
Processor with 256MB of DDR400 pc3200 memory. Every so often I get a
blue screen which says "" Driver - IRQL - Not - Less - or - Equel. And
something like physical memory dump completed. Could someone please
explain this to me.Thanks
Sponsored Links
Another Memory Dump (also known as AMD)
"Cyberdog" <david@INVALID.co.uk> wrote in message
news:n9fbs0hqcuh4gquf4gqn2r4s1go3mcetrg@4ax.com...
> Hi,
Reply to john
I got this problem when I pushed the fsb too far up. My experiences were:
Ram couldn't remain stable at higher fsb (probably not the case for you
considering I have pc2100, and you have pc3200)
There is no pci lock, or your ratios have to be setup properly
Or the northbridge can't handle the extra throughput (most likely due to
heat)
Of course, this theory relies on if you are overclocking.
Cyberdog wrote:
> Hi,
Reply to Anonymous
remember this??
>You have one single sided stick and one double sided stick. Apart from the
>chip layout they are identical. If you have trouble running both together
>you will have to swap one of them so that they are both a perfect match.
>IE, 2 x single sided or 2x double sided sticks...............by Venom
peter
> Hi,
Reply to peter
- 0 +
On Sun, 19 Dec 2004 17:42:36 +0000 (UTC), Cyberdog <david@INVALID.co.uk>
wrote:
>Hi,
On the bottom of the blue screen it may display the device driver that
is causing it. A few years ago I went threw that hell, for me it was a
creative sound blaster driver. I ended up building a new AMD so I never
did try to fix it, I just assumed the card and VIA chipset didn't get
along.
hope you sort it out, I never had a single problem with my A7N8X.
Ed
A7N8X/Barton
2-HDD/1-DVDRW/1-CDRW
Audigy 2/Radeon 9800 pro
Reply to Ed
I have the same setup and for me this problem was caused by a graphics
driver.
Mike
"Ed" <nomail@hotmail.com> wrote in message
news:jk2cs0l6vdn2f3e8s0920u23lbm6n9lspc@4ax.com...
> wrote:
>>Hi,
> along.
> Ed
> A7N8X/Barton
Reply to Anonymous
There are 853 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
