Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Hi. I am writing this because of a problem with my CD-ROM
(D:) drive. I would put an audio cd into the drive, but
whenever I try to read from the drive, windows tells me
to insert a cd into drive D:. I click cancel and try and
play it through Windows Media Player and it doesn't even
recognize the disc in the drive (but I can hear the disc
spinning). When I eject the disc, the drive doesn't stop
the disc then eject like it used to. Now it spits it out
with the disc still spinning. If anyone can help, all
help is greatly appreciated.
-RANGERGX2
P.S.: I ran PC-Doctor and it failed because it also said
that there wasn't a disc in the drive.
Sponsored Links
Try these:
http://support.microsoft.com/defau [...] -us;321641
http://support.microsoft.com/defau [...] -us;314096
Check the bottom on the second one especially ;)
Nathan McNulty
> -RANGERGX2
Reply to Anonymous
A friend's laptop has the same problem as OP. I've gone through both of these KBs and neither one
has helped.
If I switch the order of bootable devices in the BIOS, I can read a CD - but when I am running
Windows XP Home, all I can get is:
"Insert disk in Drive D:"
Along the same note, the USB drive from their camera is not recognized either.
Any other suggestions?
Thanks!
Larry
"Nathan McNulty" <nospam@msn.com> wrote in message news:OsVPrBQbEHA.3684@TK2MSFTNGP09.phx.gbl...
> Try these:
> Nathan McNulty
> > -RANGERGX2
Reply to Anonymous
I would just backup my data, format, and do a clean install. It sounds
like that install of XP is just trashed. Those two links provide
crosslinks to almost every fix in the book and if nothing in those will
fix it, Windows may just be messed up beyond repair.
Nathan McNulty
> has helped.
> Thanks!
> Larry
>>Try these:
>>http://support.microsoft.com/default.aspx?scid=kb;en-us;321641
>>http://support.microsoft.com/default.aspx?scid=kb;en-us;314096
>>Nathan McNulty
>>>-RANGERGX2
Reply to Anonymous
Yeah, thanks for your reply, becaues that's what I figured.
And, I would back up all of the data too - except... I can't use the CD to do it!
I guess it is off to X-drive for the free 15 days.
Thanks!
Larry
"Nathan McNulty" <nospam@msn.com> wrote in message news:u%23pVevZeEHA.4092@TK2MSFTNGP10.phx.gbl...
> Nathan McNulty
one
> > has helped.
> > Thanks!
> > Larry
> >>Try these:
> >>Nathan McNulty
> >>>-RANGERGX2
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > CD-ROM problems
There are 527 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
