Archived from groups: microsoft.public.windowsxp.hardware (
More info?)
Did you choose to install the Service Pack 2 Technical Beta? The only
other thing I can think of is to try that repair install
What hotfix is it that you think is causing this? They are usually very
well tested, but I guess it is possible for one to get through that
isn't of standart quality.
Nathan McNulty
anonymous@discussions.microsoft.com wrote:
> I have a firewall that is constantly on. A full virus
> scan does not reveal anything amiss. adware and spyware
> checks are also negative. My point is that the only
> programs that i downloaded were the microsoft ones on
> Friday, therefore as other users are experiencing the
> same re-boot problems there must be something wrong with
> the upgrades.
>>-----Original Message-----
>>As I mentioned in the other post, I would recommend
> scanning for viruses
>>and malware. Check your firewall settings if you have
> one, but most
>>importantly, try doing a repair installation.
>>Boot off your Windows XP CD, choose Install, Setup will
> find the
>>existing installation, choose R to repair it, and it
> should do
>>everything for you from there
>>Nathan McNulty
>>brian wrote:
>>>I have had my computer for the last 6 months with a
> adsl
>>>speedtouch usb modem. No problems until this week when
>>>all of a sudden the computer starts rebooting itself
>>>everytime I am on the internet. I have used system
>>>restore but that doesn't work so I thought what have
> io
>>>recently installed, nothing apart from windows xp
>>>upgrades. My suspicion is that one of those upgrades
> is
>>>causing a serious conflict with the usb modems.
> Microsoft
>>>please sort this out.
>>>>I have just upgraded my pc to windows XP from Windows
> 98
>>>>SE and have installed the speedtouch 330 adsl modem.
>>>>However, when i access the internet the computer
>>>>restarts.
>>>>An error message appears on the screen saying there
> was
>>>a
>>>>problem with C:\windows\system32\lsass.exe . I think
>>>this
>>>>may be a registry problem but it must have something
> to
>>>>do with the modem as it happens when on the internet.
>>>>Can anybody help?
>>>>Thanks
>>>>justin Sherlock
