HP 1220C problem initialising
Last response: in Computer Peripherals
Archived from groups: comp.periphs.printers (More info?)
Hi,
I have a HP1220c that is about 3 years old. Recently it is refusing to
work - most of the time.
Sometimes it can be persuaded to print and will then print fine for a while.
Once it has not done anything for a few hours it will be back to playing up
again!
When you turn it on it will sit there constantly
nudging the ink station wiper mechanism towards the back of the printer.
Having reached its limit it is still nudging the motor every 4 seconds or
so. At the same time the power light blinks off for a moment.
It was that behaviour that made me get a new motor for the ink station -
thinking it was not working right. (The mechanism moves easy enough)
After up to an hour of this it will either error out or move on to running
the paper feed roller and moving the print head back and forth.
In between doing this every 10 to 20 secs it will buzz from the ink station
motor.
After an hour or so of this it might decide to put the ink light on....after
which it might agree to print something. At least that's what usually
happens.
Once it works - everything works... ink station cleaning...paper pick up etc
no problems - it just does not last long.
Sorry for such a long ramble! If anyone recognises what wrong with it I'd
love to know about it. Even if it's terminal and it need to go in the waste
bin.
thanks
Robert.
"Robert Peacock" <Robert@NoSpaMahgroup.dircon.co.uk> wrote in message
news:2g8o3eF5fn45U1@uni-berlin.de...
> Hi,
while.
up
> again!
station
> motor.
on....after
> happens.
etc
waste
> bin.
> thanks
> Robert.
If you want I can email u the service manual for this printer
Martin
"Marty1a" <msmbus@nospamtiscali.co.uk> wrote in message
news:c7nl0u$oah$1@titan.btinternet.com...
> Martin
I have it thanks. Downloaded it from a ftp when I first had problems. Hasn't
helped a great deal - but at least I know how to take it apart.
It is working again at the moment. No idea if it will still work tomorrow!
I removed the encoder strip, cleaned it of ink residue and blew out the
print head where the strip goes through. That made it decide to work - but
then I've thought it fixed before...
news:2g9f3bF6e0bU1@uni-berlin.de...
> > Martin
Hasn't
The last time I had my 1220c fixed by HP with was the paper jam fitting at
the back that was causing the problems - you could try cleaning it out and
re locking it into place
Martin
Related ressources
Ask the community
Martin,
Can I obtain a copy of the service manaul you have for my own 1220C
printer, or a link to same?
Thank you very much.
Cheers: Reg
If you really do put a small value
upon yourself, rest assured that
the world will not raise the price.
"Reg" <r.coulter@saskNOSPAMtel.net> wrote in message
news:40A156E9.8A486C9B@saskNOSPAMtel.net...
> Martin,
> Cheers: Reg
I got it from a Google search - which led me to
http://fixyourownprinter.com/printer/10/9249.html
2/3rds the way down is a info to a ftp site.
If you are not ftp savvy click this ftp://ftp.nc-electronico.com in IE and
put in the user / pass from the webpage. The site still connects - don't
know if the manual is still there though.
HTH
Robert.
> Martin,
> Cheers: Reg
If you still need the manual = email me at m.moorhead2003nospam@virgin.net
watch out for the spam trap
Martin
Martin,
Thank you. I was able to locate the manual this am.
Cheers: Reg
Ask the community
