A7V400-MX Mouse Light On After Power Off
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Is there anyway to turn this off? KBPWR jumper?
TIA
G
Guest
Guest
> TIA
Disable all ps2kb and ps2ms if you have a usb mouse/kb disable all usb
power options. The usb and kb will still work, just not when the power
is off, so in essence, you can't use wake on mouse or kb.
Hope it helps.
G
Guest
Guest
"BillyBoy" <noreply@earthlink.net> wrote in message
news:wwcBd.8156$qf5.7036@newsread3.news.atl.earthlink.net...
> TIA
On some boards there is an option for whether the mouse can 'wake' the
machine in the BIOS. This will sometimes turn off the power.
It is particularly annoying on some designs of 'wireless' mice, where
having power to the receiver module, prevents them going to sleep, and
runs the batteries down... :-(
Unfortunately, it is becoming more common on modern machines for larger
numbers of peripherals to remain awake. I turn off the UPS, which switches
everything off...
Best Wishes
G
Guest
Guest
Both KB and Mouse are PS2. All power options are disabled.
"Browser Joe" <i.dont@think.so> wrote in message
news:F1gBd.43369$nV.1341814@news20.bellglobal.com...
> TIA
Hope it helps.
G
Guest
Guest
This is an IntelliMouse Optical USB or PS2. I just changed it to USB and
it's fine. However, my experience is that PS2 is more stable.
news:BMhBd.4594$JC2.2509@newsread2.news.atl.earthlink.net...
> TIA
Hope it helps.
