G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I downloaded the Windows BIOS update utility (AsusUpdate V6.02.01) to
update my bios version from 1009 to 1010 beta version.
The utility erase ROM, then Flash ROM successefully, but when
verifying ROM it reaches 1% and then it displays message: "Fail to
verify EEPROM with new BIOS image. Please press button to try
again or [EXIT] to abort".
I know that the minute I shutdown Windows I won't be able to reboot my
PC. How can I fix the problem?
Thank you very much.
Nidhal.
MB is: A7V133
Nidhal.
MB is: A7V133
