G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus,alt.comp.hardware.amd.x86-64 (More info?)
I've been running this board for about a week now. From the beginning, the
fan speeds were ~ 3000 for the stock AMD HSF and ~ 3600 for the case intake.
All was well. Today when I booted up, I got a verbal warning that the "CPU
fan fail". Checking the fan physically revealed it to be working as always
(noise the same as before, so I believe the actual speed to be unchanged).
I should also say that the CPU and case temperatures remain the same as
before the fan speed "change", 31C CPU and 23C case as I type this. FWIW,
Cool 'n' Quiet remains disabled in the BIOS.
Checking in the BIOS revealed that both fans were showing half their
previous speed (now ~1485 for the CPU fan and ~1800 for the intake fan) and
that the CPU fan speed is in red, indicating a problem. I'm guessing the
threshold is 1500 RPM?
I've temporarily disabled monitoring of the CPU fan so as not to get the
"press F1 to continue" each time I boot.
I have reflashed the 1009 BIOS on the off-chance something was a bit off,
and reverted to defaults to eliminate the possibility that I set something
incorrectly. The warning is still there unless I disable the monitor.
Having searched through the BIOS settings and the motherboard manual for any
way that I could have caused the change, or any way to rectify the
situation, I've found nothing.
Anybody know what's going on and how I can get the correct readings back?
TIA!
TIA!
