Tom's Hardware > Forum > Motherboards & Memory > Asus > Help needed with STRANGE ram problem
Forum Motherboards & Memory : Asus - Help needed with STRANGE ram problem
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I have a rev 2.0 A7N8X Deluxe board that's been running flawlessly for a
year with a 2100+ and for the past six months with two 512 meg Kingston
pc3200 dimms (KVR400x64C3A/512). A few days ago I upgraded the cpu to a
3200+, and I've been having stability problems ever since.
It all seems to be related to the RAM
Sponsored Links
In article <I4SDd.206020$Np3.8676236@ursa-nb00s0.nbnet.nb.ca>, "JM"
What happens when you drop the clock rate for the processor,
from 200MHz to 180MHz. Does the stability improve ?
The Nforce2 is picky about RAM, and the issue tends to show up
when you run a processor that uses a 200Mhz clock (FSB400).
Here is a summary of your options:
http://groups.google.ca/groups?sel [...] 177&rnum=5
The nforcershq.com web site has plenty of user experiences
to read about, and that is a good place to do some searches
about RAM on the A7N8X.
Good luck,
Paul
Reply to Paul
There are 1174 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
