G
Guest
Guest
Archived from groups: alt.comp.hardware,alt.comp.periphs.mainboard.asus (More info?)
Mobo: Asus K8N-E Delexe (with onboard gigabit ethernet)
OS: Windows XP SP2 fully up to date, spyware scanned and virus scanned with
a fully up to date AVG Free.
Router: Origo 4 Port ASR-8400
I have a home network set up which, until recently worked fine. I am using
the router to connect three PCs and provide them with internet access. On my
machine I am no longer able to see the network. I have got the following
info:
IPCONFIG (notice the missing addresses):
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Autoconfiguration IP Address. . . : 169.254.226.157
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :
PING:
All other computers on the network can ping 10.0.0.2 which is the address
the router is at. My computer just says that the host is unreachable.
TCP/IP Properties:
Set to get IP address automatically as is every other computer on the
network.
I have also tried changing sockets and network cables in which the computer
is plugged into the router with.
I have tried replacing the onboard gigabit ethernet adapter with a seperate
PCI card and that seems t work just fine. The new PCI card sets up a new
Local Area Connection and I'm hoping that there is some sort of
configuration problem witht he original one that uses the onboard ethernet.
Using the seoerate PCI card I can do an IPCONFIG and get:
Ethernet adapter Local Area Connection 3:
IP Address. . . . . . . . . . . . : 10.0.0.13
Subnet Mask . . . . . . . . . . . : 255.0.0.0
Default Gateway . . . . . . . . . : 10.0.0.2
Is there anything else I can do/check or is this a case of a bad motherboad
(one month old!) that I should RMA?
TIA
info:
PING:
TCP/IP Properties:
network.
TIA
