A7V400-MX boot and onboard audio problems
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I'm taking a survey to see how commone the following problems are:
Boot problem 1: Everytime I turn power on from a cold start, boot starts
for about 2 seconds, then HDD and power lamps go off for about 2
seconds, then come on and boot continues normally. Definitely not a
power supply problem. Does your m/b ever do this?
Boot problem 2: Sometimes, I get a message that the keyboard is locked
out and there is no response to any key presses. If I then hit Reset,
next boot proceeds normally. Ever happen to you?
Audio problem: Can't get onboard audio to work. I thought I installed
all the drivers properly and have AC97 enabled in the BIOS. Have any of
you ever got onboard audio to work?
All I'm looking for are simple Yes/No answers to each question. If most
of you do NOT have these problems, I'll assume that my m/b is defective
and exchange it.
Thanks for your help.
Ray
4 answers Last reply
More about a7v400 boot onboard audio problems
  1. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    No
    No
    My onboard audion work as expected
    I used to have a t-bird 1GHz on it and now I have a xp-m 2500+. Both work.
  2. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    Thanks for the feeback.
    Ray
  3. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    On Wed, 12 Jan 2005 10:34:57 -0800, No e-mail
    >No
    FWIW - I have this happen on my A7V8X-MX mobo
    >No
  4. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    >>No
    I just built up a box with a A7V400-MX today, and it does it too.
Asus Audio Boot Motherboards
