Archived from groups: microsoft.public.windows.networking.wireless (More info?)
Hi-
I've got my home wireless network working now, including being able to print
from my laptop to a printer connected to my desktop (with both machines
connected wirelessly through a router). There are a number of reasons why
this wireless setup is superior, for my use, to a physical connection to the
desktop with a LAN cable.
However, there are some things I'd like to do through the desktop that would
probably go much faster using a LAN connection. Can I set up a second
network that lets me connect my laptop directly to the desktop using a LAN
cable? Do I need any special accessories or software to do this? In
particular, the desktop HD is much larger than the laptop and I like to
backup files onto the desktop (say 5 to 10 GB worth). Am I correct in
thinking this would move much faster over the LAN than wirelessly?
personallky, i found the whole system to be alot faster when i changed to
wireless from a lan.
however, i concur with your thoughts of a cat5 lan would be faster for file
transfer.
if you have a spare pair of nic sockets then set another net up for file
transfer, the set up should be very easy.
mike
"ABC" <kdstrawn@wisc.edu> wrote in message
news:SFYFd.10163$006.851@fe05.lga...
> Hi-
print
the
would
LAN
> Thanks for any help.
> Kelley
This would be much faster as you will be connecting at 100mps (Assuming you
have a recent network card in both) What you need is a CROSSOVER cable, this
will eliminate the need for another hub.
"ABC" wrote:
> Hi-
> Kelley
