G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Im having a problem with graphics driver getting blue screen of error type when trying to play games that says problem with graphic driver, system is virus and adware clean, ive been back and forth with the driver versions etc etc. took it to a shop and guy looked at me like a fish so here it is...
1. This is from event viewer...
Event Type: Error
Event Source: System Error
Event Category: (102)
Event ID: 1003
Date: 7/25/2004
Time: 11:39:00 PM
User: N/A
Computer: BADELF
Description:
Error code 000000d1, parameter1 486e0902, parameter2 00000002, parameter3 00000001, parameter4 f806005d.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 53 79 73 74 65 6d 20 45 System E
0008: 72 72 6f 72 20 20 45 72 rror Er
0010: 72 6f 72 20 63 6f 64 65 ror code
0018: 20 30 30 30 30 30 30 64 000000d
0020: 31 20 20 50 61 72 61 6d 1 Param
0028: 65 74 65 72 73 20 34 38 eters 48
0030: 36 65 30 39 30 32 2c 20 6e0902,
0038: 30 30 30 30 30 30 30 32 00000002
0040: 2c 20 30 30 30 30 30 30 , 000000
0048: 30 31 2c 20 66 38 30 36 01, f806
0050: 30 30 35 64 005d
this is cut and paste of dxdiag....
System Information
Time of this report: 7/26/2004, 00:10:48
Machine name: BADELF
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 1 (2600.xpsp2.030422-1633)
Language: English (Regional Setting: English)
System Manufacturer: n/a
System Model: n/a
BIOS: Award Modular BIOS v6.0
Processor: AMD Athlon(TM) XP 2000+, MMX, 3DNow, ~1.7GHz
Memory: 512MB RAM
Page File: 219MB used, 1031MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0b (4.09.0000.0902)
DX Setup Parameters: Not found
DxDiag Version: 5.03.0001.0902 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce FX 5600
Manufacturer: NVIDIA
Chip type: GeForce FX 5600
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0312&SUBSYS_040110B0&REV_A1
Display Memory: 256.0 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor: Default Monitor
Monitor Max Res:
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.5672 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 3/24/2004 10:04:00, 4274560 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 3/24/2004 10:04:00, 1895648 bytes
Device Identifier: {D7B71E3E-4052-11CF-2865-0B2400C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0312
SubSys ID: 0x040110B0
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: SoundMAX Digital Audio
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1106&DEV_3059&SUBSYS_80A11043&REV_50
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: smwdm.sys
Driver Version: 5.12.0001.3663 (English)
WHQL Logo'd: Yes
Date and Size: 7/15/2003 16:00:00, 578368 bytes
Other Files:
Driver Provider: Analog Devices
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 100, 48000
Static/Strm HW Mix Bufs: 33, 32
Static/Strm HW 3D Bufs: 33, 32
HW Memory: 0
Voice Management: Yes
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): Yes
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xCCC
DirectMusic
DLS Path: C:\WINDOWS\system32\drivers\gm.dls
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
SoundMAX Digital Audio, Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SoundMAX Wavetable Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x1106, 0x3038
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 7/3/2003 17:52:58, 53120 bytes
| Driver: usbd.sys, 3/31/2003 05:00:00, 4736 bytes
Gameport Devices
+ VIA Standard PCI to ISA Bridge
| Matching Device ID: pci\ven_1106&dev_3177
| Service: isapnp
| Driver: isapnp.sys, 8/17/2001 13:58:02, 35840 bytes
+-+ Standard Game Port
| | Matching Device ID: *pnpb02f
| | Service: gameenum
| | Driver: gameenum.sys, 3/31/2003 05:00:00, 9856 bytes
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 3/31/2003 05:00:00, 51072 bytes
| Driver: kbdclass.sys, 3/31/2003 05:00:00, 23424 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/29/2002 03:46:42, 38024 bytes
+ Microsoft PS/2 Mouse
| Matching Device ID: *pnp0f03
| Service: i8042prt
| Driver: mouclass.sys, 3/31/2003 05:00:00, 22016 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.0000.0903)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.0000.0903)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.0000.0900)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.0000.0900)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: Local Area Connection 2 - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 69.2 GB
Total Space: 76.3 GB
File System: NTFS
Model: ST380013A
Drive: E:
Free Space: 1.1 GB
Total Space: 2.0 GB
File System: FAT
Model: FUJITSU MPC3032AT
Drive: F:
Free Space: 0.5 GB
Total Space: 1.0 GB
File System: FAT
Drive: D:
Model: LITE-ON CD-ROM LTN-527T
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.1106 (English), 3/31/2003 05:00:00, 47488 bytes
System Devices
Name: Linksys LNE100TX Fast Ethernet Adapter(LNE100TX v4) #2
Device ID: PCI\VEN_1317&DEV_0985&SUBSYS_05741317&REV_11\3&61AAA01&0&70
Driver: C:\WINDOWS\System32\DRIVERS\an983.sys, 2.17.1025.2001 (English), 8/28/2002 22:59:12, 36224 bytes
Name: VIA CPU to AGP2.0/AGP3.0 Controller
Device ID: PCI\VEN_1106&DEV_B198&SUBSYS_00000000&REV_00\3&61AAA01&0&08
Driver: C:\WINDOWS\System32\DRIVERS\VIAAGP1.SYS, 5.01.0000.3442 (English), 7/2/2003 04:42:00, 27904 bytes
Name: VIA Standard Host Bridge
Device ID: PCI\VEN_1106&DEV_3189&SUBSYS_00000000&REV_80\3&61AAA01&0&00
Driver: n/a
Name: VIA Standard PCI to ISA Bridge
Device ID: PCI\VEN_1106&DEV_3177&SUBSYS_00000000&REV_00\3&61AAA01&0&88
Driver: C:\WINDOWS\System32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/17/2001 13:58:02, 35840 bytes
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_1106&DEV_3104&SUBSYS_80A11043&REV_82\3&61AAA01&0&83
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.1243 (English), 7/3/2003 17:50:46, 25216 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.1243 (English), 7/3/2003 17:49:30, 138752 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.1243 (English), 7/3/2003 17:52:58, 53120 bytes
Driver: C:\WINDOWS\System32\hccoin.dll, 5.01.2600.1243 (English), 7/3/2003 17:50:12, 5632 bytes
Driver: C:\WINDOWS\System32\usbui.dll, 5.01.2600.0000 (English), 3/31/2003 05:00:00, 67072 bytes
Name: VIA Rhine II Fast Ethernet Adapter
Device ID: PCI\VEN_1106&DEV_3065&SUBSYS_80A11043&REV_74\3&61AAA01&0&90
Driver: C:\WINDOWS\System32\DRIVERS\fetnd5b.sys, 3.35.0000.0420 (English), 6/10/2004 11:22:12, 42496 bytes
Driver: C:\WINDOWS\System32\wcoinst.dll, 1.00.0000.0008 (English), 6/2/2004 14:28:46, 10656 bytes
Name: SoundMAX Integrated Digital Audio
Device ID: PCI\VEN_1106&DEV_3059&SUBSYS_80A11043&REV_50\3&61AAA01&0&8D
Driver: n/a
Name: VIA Rev 5 or later USB Universal Host Controller
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_80A11043&REV_80\3&61AAA01&0&82
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.1243 (English), 7/3/2003 17:51:46, 19328 bytes
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_80A11043&REV_80\3&61AAA01&0&81
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_80A11043&REV_80\3&61AAA01&0&80
Name: VIA Bus Master IDE Controller
Device ID: PCI\VEN_1106&DEV_0571&SUBSYS_80A11043&REV_06\3&61AAA01&0&89
Driver: C:\WINDOWS\System32\DRIVERS\viaide.sys, 1.00.0001.0000 (English), 3/31/2003 05:00:00, 4864 bytes
Driver: C:\WINDOWS\System32\DRIVERS\pciidex.sys, 5.01.2600.1106 (English), 3/31/2003 05:00:00, 23680 bytes
Driver: C:\WINDOWS\System32\DRIVERS\atapi.sys, 5.01.2600.1106 (English), 3/31/2003 05:00:00, 86912 bytes
Name: NVIDIA GeForce FX 5600
Device ID: PCI\VEN_10DE&DEV_0312&SUBSYS_040110B0&REV_A1\4&1FEB96E4&0&0008
Driver: C:\WINDOWS\System32\DRIVERS\nv4_mini.sys, 6.14.0010.5672 (English), 3/24/2004 10:04:00, 1895648 bytes
Driver: C:\WINDOWS\System32\nvinstnt.dll, 6.14.0010.5672 (English), 3/24/2004 10:04:00, 131072 bytes
Driver: C:\WINDOWS\System32\nvsvc32.exe, 6.14.0010.5672 (English), 3/24/2004 10:04:00, 110659 bytes
Driver: C:\WINDOWS\System32\nvcod.dll, 1.00.0000.0015 (English), 3/24/2004 10:04:00, 32256 bytes
Driver: C:\WINDOWS\System32\nvcodins.dll, 1.00.0000.0015 (English), 3/24/2004 10:04:00, 32256 bytes
Driver: C:\WINDOWS\System32\nv4_disp.dll, 6.14.0010.5672 (English), 3/24/2004 10:04:00, 4274560 bytes
Driver: C:\WINDOWS\System32\nvoglnt.dll, 6.14.0010.5672 (English), 3/24/2004 10:04:00, 4874240 bytes
Driver: C:\WINDOWS\System32\nvcpl.dll, 6.14.0010.5672 (English), 3/24/2004 10:04:00, 3309568 bytes
Driver: C:\WINDOWS\System32\nvmctray.dll, 6.14.0010.5672 (English), 3/24/2004 10:04:00, 46080 bytes
Driver: C:\WINDOWS\System32\nvwddi.dll, 6.14.0010.5672 (English), 3/24/2004 10:04:00, 36864 bytes
Driver: C:\WINDOWS\System32\nvwdmcpl.dll, 6.14.0010.5672 (English), 3/24/2004 10:04:00, 1617920 bytes
Driver: C:\WINDOWS\System32\nvnt4cpl.dll, 6.14.0010.5672 (English), 3/24/2004 10:04:00, 241664 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 3/24/2004 10:04:00, 87403 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 3/24/2004 10:04:00, 49796 bytes
DirectX Components
ddraw.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 257536 bytes
ddrawex.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 24064 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 10496 bytes
d3d8.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 1156608 bytes
d3d8thk.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 8192 bytes
d3d9.dll: 5.03.0001.0902 English Final Retail 5/30/2003 09:00:02 1613312 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 436224 bytes
d3dim700.dll: 5.03.0001.0902 English Final Retail 5/30/2003 09:00:02 797184 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 3/31/2003 05:00:00 33040 bytes
dplayx.dll: 5.03.0000.0903 English Final Retail 4/14/2004 14:56:46 219648 bytes
dpmodemx.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 22016 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 3/31/2003 05:00:00 42768 bytes
dpwsockx.dll: 5.03.0000.0903 English Final Retail 4/12/2004 23:11:26 76800 bytes
dplaysvr.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 28160 bytes
dpnsvr.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 16896 bytes
dpnet.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 377856 bytes
dpnlobby.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 3072 bytes
dpnaddr.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 3072 bytes
dpvoice.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 203264 bytes
dpvsetup.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 80896 bytes
dpvvox.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 112128 bytes
dpvacm.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 19968 bytes
dpnhpast.dll: 5.03.0000.0901 English Final Retail 3/24/2003 09:00:02 32768 bytes
dpnhupnp.dll: 5.03.0000.0901 English Final Retail 3/24/2003 09:00:02 68096 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 3/31/2003 05:00:00 53520 bytes
dinput.dll: 5.01.2600.1106 English Final Retail 8/29/2002 03:40:00 151552 bytes
dinput8.dll: 5.01.2600.1106 English Final Retail 8/29/2002 03:40:00 168960 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 394240 bytes
joy.cpl: 5.01.2600.1106 English Final Retail 8/29/2002 03:41:00 208896 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 223232 bytes
pid.dll: 5.01.2600.1106 English Final Retail 8/29/2002 03:41:00 31744 bytes
gameenum.sys: 5.01.2600.1106 English Final Retail 3/31/2003 05:00:00 9856 bytes
dsound.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 336384 bytes
dsound3d.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 1294336 bytes
dswave.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 18432 bytes
dsdmo.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 186880 bytes
dsdmoprp.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 68096 bytes
dmusic.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 97280 bytes
dmband.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 27136 bytes
dmcompos.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 58368 bytes
dmime.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 171520 bytes
dmloader.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 33280 bytes
dmstyle.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 98816 bytes
dmsynth.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 100864 bytes
dmscript.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 76800 bytes
system.dll: 1.01.4322.0573 English Final Retail 5/22/2004 16:07:38 1216512 bytes
dx7vb.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 602624 bytes
dx8vb.dll: 5.03.0001.0902 English Final Retail 5/30/2003 09:00:02 1189888 bytes
dxdiagn.dll: 5.03.0001.0902 English Final Retail 5/30/2003 09:00:02 1675264 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 3/31/2003 05:00:00 924432 bytes
mfc42.dll: 6.00.8665.0000 English Beta Retail 3/31/2003 05:00:00 995383 bytes
wsock32.dll: 5.01.2600.0000 English Final Retail 3/31/2003 05:00:00 21504 bytes
amstream.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 64512 bytes
devenum.dll: 6.05.0001.0902 English Final Retail 5/30/2003 09:00:02 53248 bytes
dxmasf.dll: 6.04.0009.1125 English Final Retail 3/31/2003 05:00:00 498205 bytes
mciqtz32.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 34304 bytes
mpg2splt.ax: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 136192 bytes
msdmo.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 13312 bytes
encapi.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 18944 bytes
qasf.dll: 9.00.0000.2980 English Final Retail 12/11/2002 17:34:40 241664 bytes
qcap.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 177152 bytes
qdv.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 268800 bytes
qdvd.dll: 6.05.0001.0902 English Final Retail 5/30/2003 09:00:02 355840 bytes
qedit.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 524800 bytes
qedwipes.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 733184 bytes
quartz.dll: 6.05.0001.0902 English Final Retail 5/30/2003 09:00:02 1246208 bytes
strmdll.dll: 4.01.0000.3928 English Final Retail 3/31/2003 05:00:00 251904 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 11/14/2002 12:58:00 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 11/14/2002 12:58:00 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 11/14/2002 12:58:02 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 11/14/2002 12:58:02 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 11/14/2002 12:58:02 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 11/14/2002 12:58:04 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 11/14/2002 12:58:04 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 11/14/2002 12:58:06 154624 bytes
mswebdvd.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 194560 bytes
ks.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 130304 bytes
ksproxy.ax: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 117248 bytes
ksuser.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 4096 bytes
stream.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 45696 bytes
mspclock.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 5248 bytes
mspqm.sys: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 4608 bytes
mskssrv.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 7424 bytes
swenum.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 4096 bytes
mstee.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 5504 bytes
bdaplgin.ax: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:26 16896 bytes
bdasup.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:26 11392 bytes
msdvbnp.ax: 6.05.0001.0900 English Final Retail 2/17/2003 10:16:26 52224 bytes
psisdecd.dll: 6.05.0001.0900 English Final Retail 2/17/2003 10:16:28 354816 bytes
psisrndr.ax: 6.05.0001.0900 English Final Retail 2/17/2003 10:16:28 30208 bytes
ipsink.ax: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:26 14848 bytes
mpeg2data.ax: 6.05.0001.0900 English Final Retail 2/17/2003 10:16:26 57856 bytes
ndisip.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:28 10112 bytes
mpe.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:26 15104 bytes
streamip.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:28 14976 bytes
msvidctl.dll: 6.05.0001.0900 English Final Retail 2/17/2003 10:16:28 1230336 bytes
slip.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:28 10880 bytes
nabtsfec.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:28 83968 bytes
ccdecode.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:26 16384 bytes
vbisurf.ax: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:30 27648 bytes
msyuv.dll: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:28 16896 bytes
kstvtune.ax: 5.03.0001.0902 English Final Retail 6/4/2003 10:30:32 274432 bytes
ksxbar.ax: 5.03.0001.0902 English Final Retail 6/4/2003 09:18:28 39424 bytes
kswdmcap.ax: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:32 226304 bytes
wstcodec.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:32 18688 bytes
wstdecod.dll: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:32 47104 bytes
msdv.sys: 5.01.2600.0000 English Final Retail 2/17/2003 10:21:50 52096 bytes
Event Type: Error
Event ID: 1003
Date: 7/25/2004
Time: 11:39:00 PM
User: N/A
Computer: BADELF
Description:
Data:
System Information
System Model: n/a
Memory: 512MB RAM
DxDiag Notes
Direct3D: 0/4 (n/a)
Display Devices
Monitor Max Res:
WHQL Logo'd: Yes
VDD: n/a
Vendor ID: 0x10DE
Device ID: 0x0312
Revision ID: 0x00A1
Revision ID: 0x00A1
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF5F
HW Memory: 0
Registry: OK
Cap Flags: 0x41
Format Flags: 0xCCC
DirectMusic
Acceleration: n/a
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: n/a
FF Driver: n/a
Registry: OK
USB Devices
+ USB Root Hub
| Service: usbhub
Gameport Devices
| Service: isapnp
| | Service: gameenum
PS/2 Devices
| Service: i8042prt
| Service: TermDD
| Service: i8042prt
| Service: TermDD
Registry: OK
DirectPlay Adapters
MS-PCM 64 kbit/s
Drive: C:
Free Space: 69.2 GB
File System: NTFS
Model: ST380013A
Drive: E:
Free Space: 1.1 GB
Total Space: 2.0 GB
File System: FAT
Drive: F:
Free Space: 0.5 GB
Total Space: 1.0 GB
File System: FAT
Drive: D:
System Devices
Driver: n/a
Driver: n/a
DirectX Components
