Archived from groups: alt.comp.periphs.mainboard.asus (
More info?)
In article <1106065861.768094.187740@f14g2000cwb.googlegroups.com>,
cranbrook@attbi.com wrote:
> Wiring worked...thanks.
> I however have not been able to get the mic set up to work with either
> front or rear port. The case and front panel labels are pretty
> confusing, I think I have it wrong. Any clues?
> Five wire front port cables are labelled:
> gnd, gnd, L speaker, R speaker, mic
> K8N offers:
> mic2, agnd, micpwr, +5A, lineout R,BLineOutR, NC, lineout L, BLineOutL.
OK. Your case has two grounds, and that _could_ be a problem.
On a good case, the grounds are joined inside the case, and
if that is the way your case is designed, then only one of the
two ground wires would need to be connected.
If the company that made your case was lazy, the grounds could
be separate.
In any case, start by connecting the "mic" wire to the MIC2
pin on the Asus 2x5 header. Plug in a Walkman or other
line level test source. Now, go into the mixer or audio
control panel for the onboard sound, and find a hidden setting
that selects between front and back microphone. It could be
labelled something like MIC1/MIC2 or the like.
The purpose of the Walkman or other kind of line level (1 volt
AC) type test signal, is to find out if the wiring is complete
or not. If, with MIC2 selected on the computer, and the Walkman
plugged in, it could be that the second ground wire really needs
to be connected.
To find an extra ground pin, you can find GND pins on the
USB headers. Have a look in the manual, for other motherboard
headers with a ground connection. In the past, I've recommended
using one of the two ground pins on the AUX 1x4 audio header,
and that is fine, except that the pins might be too small to
hold your case wire securely.
Now, the next issue, will be the use of electret microphones.
A 1/8" stereo type plug, has three contacts. This epanorama
web page has a picture of the plug on an electret mic:
http://www.epanorama.net/links/audiopro.html (main page)
http://www.epanorama.net/circuits/microphone_powering.html
| | Audio signal == MIC2
| | Bias voltage for microphone (+5V through 2.2 kohm resistor)
|===| == MICPWR
| | Ground == AGND
Your computer case has no way to get MICPWR to the second
contact on the jack. Which means an electret microphone won't
work, with just MIC2 and AGND connected normally. But other
kinds of mono sources might work, like the Walkman used for
this test. (For passive microphones, you'll need to enable
the 20dB microphone boost button, but in some cases, even that
is not enough. An electret is much better for the average
recording application with the MIC input. A passive microphone
equipped with a preamp will also work. Of course, the mic input
on the back of the computer will have MICPWR on its second
contact.)
You could either look at some of the powering options
noted on the microphone_powering web page, or find a better
drive bay mounted set of jacks. The Asus J-Panel drive bay
mounted product, has ear and microphone jacks, and they
mate exactly with an FPAUDIO header. The J-Panel also
has SPDIF and USB connectors. The first one I could find for
sale via a search engine, is here:
http://www.pcplanets.com/item.asp?item=633
HTH,
Paul
