Does 32bit hardware working in 64bit PC?
Adam
343
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I have an AMD Athlon 64 3200+ PC. When ever I try to
install my wireless NIC I get "Device Could Not Start
(Code 10). I'm positive that I've installed it correctly
and I've updated everything, including flashing my bios.
I know the card works in my older PC (AMD Athlon 2100+).
This leads me to believe that maybe there is a problem
with the 64bit part of my new PC! Could my problem be
that my Belkin NIC was only designed to work under 32 bit?
G
Guest
Guest
"ADAM" <anonymous@discussions.microsoft.com> wrote in message
news:5e7201c474c9$2657bff0$a401280a@phx.gbl...
Unless your using the 64bit version of windows
you don't need 64bit drivers. If you are using a 64bit version
of XP I've found drivers on www.planetamd64.com but
you have to register. Also search on google or ask in the
groups Carey posted. I would also disable anything on the
board I wasn't using like onboard NICs.
Jim M
G
Guest
Guest
Newsgroup Support for Windows for 64-Bit Extended Systems
http://www.microsoft.com/windowsserver2003/64bit/extended/trial/support.mspx
List of Limitations in 64-Bit Windows
http://support.microsoft.com/default.aspx?scid=kb;en-us;282423&Product=winxp
Cannot Install Some Programs on Windows XP for 64-bit Platforms
http://support.microsoft.com/default.aspx?scid=kb;en-us;298218&Product=winxp
Carey Frisch
Microsoft MVP
Windows XP - Shell/User
Be Smart! Protect your PC!
http://www.microsoft.com/security/protect/
"ADAM" <anonymous@discussions.microsoft.com> wrote in message:
