Archived from groups: microsoft.public.windows.networking.wireless (More info?)
Hello. I've been fooling around with the pc and laptop and I made some
progress. The pc (directly connected to the router) can see both itself and
the other computer called the laptop. However, when clicking on laptop it
tells me I do not have access permissions. Now on the laptop it can see its
own files but when clicking on "view workgroup computers" it tells me that
mshome is not accessible. I think I am close to a solution. All I want is a
simple file share. I took some shots of my wireless configuration. You can
see them at http://www.pdopticsinc.com/net/config.htm. Please help. I am
going crazy!
I have been reading the boards and found out how to do a ping. The bad news
is both pc's share the same ip address??? I am using a router. Thanks
RJP
> going crazy!
> Again, Thanks
> RJP
Update: I stopped the computer browser on the laptop only and installed
netbuei on the laptop. Still no change. Ill post more as I do it.
Thanks
RJP
> RJP
> > going crazy!
> > Again, Thanks
> > RJP
Almost forgot. After stopping the browser service and installing netbeui on
the laptop the pc gets the same mshome is not accessible error. Please help!
THanks
RJP
> Thanks
> RJP
> > RJP
> > > going crazy!
> > > Again, Thanks
> > > RJP
Both PCs should not have the same IP address. The router has a IP address
that the internet will see, but each PC should have its own IP. If you have
a router and 2 PCs there should be 3 unique IP addresses.
"M76" <M76@discussions.microsoft.com> wrote in message
news:7B17A802-913F-4CB8-BE5E-8872300DDC60@microsoft.com...
>news
> RJP
>> and
>> it
>> its
>> that
>> is a
>> can
>> am
>> going crazy!
>> Again, Thanks
>> RJP
set the router to dchp on
set pc's to obtain ip automatically.
mike
"Robert Jacobs" <rjacobs0spamfree@pacbell.net> wrote in message
newsky5mK3%23EHA.1084@tk2msftngp13.phx.gbl...
have
> >news
> > RJP
itself
> >> and
> >> it
see
> >> its
> >> that
want
> >> is a
You
> >> can
> >> am
> >> going crazy!
> >> Again, Thanks
> >> RJP
How would I give each one its own ip and fix it?
Thanks
RJP
> >news
> > RJP
> >> and
> >> it
> >> its
> >> that
> >> is a
> >> can
> >> am
> >> going crazy!
> >> Again, Thanks
> >> RJP
You need to set your router to DHCP enabled by logging into the router. and
then open your wireless connection status window, on the General tab goto
Properties, click on the Internet Protocol (TCP/IP) optiona and goto
Properties. Make sure the options "Obtain an IP Address Automatically" and
"Obtain DNS server address automatically" are selected, then goto the
Alternate Configuration Tab and select the "Automatic private IP address"
option, then press OK. After all this restart your system and router and see
if that works.
For Future Info, it would be good to let us know what model router you are
using and the OS's you are using on your computers.
news:486F37B1-8E9E-4FB5-8F59-803B10B9F778@microsoft.com...
> Thanks
> RJP
>> have
>> >news
>> > RJP
>> >> some
>> >> itself
>> >> and
>> >> laptop
>> >> it
>> >> see
>> >> its
>> >> that
>> >> want
>> >> is a
>> >> You
>> >> can
>> >> I
>> >> am
>> >> going crazy!
>> >> Again, Thanks
>> >> RJP
I am very lost. I have a linksys router. How would I do this?
> if that works.
> > Thanks
> > RJP
> >> have
> >> >news
> >> > RJP
> >> >> some
> >> >> itself
> >> >> and
> >> >> laptop
> >> >> it
> >> >> see
> >> >> its
> >> >> that
> >> >> want
> >> >> is a
> >> >> You
> >> >> can
> >> >> I
> >> >> am
> >> >> going crazy!
> >> >> Again, Thanks
> >> >> RJP
I found out how to use my router config and no I have unique IP addresses. I
tried ping again. I can ping the PC from the laptop with no problem.
However when I tried to ping the laptop from the pc it timed out. Any clues?
Thanks again
RJP
> if that works.
> > Thanks
> > RJP
> >> have
> >> >news
> >> > RJP
> >> >> some
> >> >> itself
> >> >> and
> >> >> laptop
> >> >> it
> >> >> see
> >> >> its
> >> >> that
> >> >> want
> >> >> is a
> >> >> You
> >> >> can
> >> >> I
> >> >> am
> >> >> going crazy!
> >> >> Again, Thanks
> >> >> RJP
Have you run the Wireless network configuration wizard on your computers?
can you access the internet on either of your systems?
"RJP" <RJP@discussions.microsoft.com> wrote in message
news:492F57AD-A834-4ADD-B549-313C4C64322E@microsoft.com...
>I
> clues?
> Thanks again
> RJP
>> and
>> and
>> see
>> if that works.
>> are
>> > Thanks
>> > RJP
>> >> address
>> >> have
>> >> >bad
>> >> >news
>> >> > Thanks
>> >> > RJP
>> >> >> some
>> >> >> itself
>> >> >> and
>> >> >> laptop
>> >> >> it
>> >> >> can
>> >> >> see
>> >> >> its
>> >> >> me
>> >> >> that
>> >> >> want
>> >> >> is a
>> >> >> You
>> >> >> can
>> >> >> help.
>> >> >> I
>> >> >> am
>> >> >> going crazy!
>> >> >> Again, Thanks
>> >> >> RJP
Have you tried to turn off the firewall (right click on the network icon in
the systray and click on change windows firewall settings)
Volunteer your CPU to power global research http://www.grid.org/about/ > Sign up and join the team
> http://www.grid.org/services/teams [...] 8F3AF77CCA "RJP" <RJP@discussions.microsoft.com> wrote in message
>I
> clues?
> Thanks again
> RJP
>> and
>> and
>> see
>> if that works.
>> are
>> > Thanks
>> > RJP
>> >> address
>> >> have
>> >> >bad
>> >> >news
>> >> > Thanks
>> >> > RJP
>> >> >> some
>> >> >> itself
>> >> >> and
>> >> >> laptop
>> >> >> it
>> >> >> can
>> >> >> see
>> >> >> its
>> >> >> me
>> >> >> that
>> >> >> want
>> >> >> is a
>> >> >> You
>> >> >> can
>> >> >> help.
>> >> >> I
>> >> >> am
>> >> >> going crazy!
>> >> >> Again, Thanks
>> >> >> RJP
Finally!!!! My network works! I ran the wireless network wizard, disabled
norton firewall and all works. Now the last thing. I am trying to transfer
a 2.56gig folder from one comp to the next over my wireless connection. It
tells me it will take 101 minutes when I drag it through win explorer and
then hangs. How can I do this the reliable and quick way? Here is an image
of my wireless network connection (
http://www.pdopticsinc.com/palka/net.jpg). ANy help will be appreciated and
thanks so much for everything already!
RJP
> Volunteer your CPU to power global research http://www.grid.org/about/ > > Sign up and join the team
> > http://www.grid.org/services/teams [...] 8F3AF77CCA > "RJP" <RJP@discussions.microsoft.com> wrote in message
> >I
> > clues?
> > Thanks again
> > RJP
> >> and
> >> and
> >> see
> >> if that works.
> >> are
> >> > Thanks
> >> > RJP
> >> >> address
> >> >> have
> >> >> >bad
> >> >> >news
> >> >> > Thanks
> >> >> > RJP
> >> >> >> some
> >> >> >> itself
> >> >> >> and
> >> >> >> laptop
> >> >> >> it
> >> >> >> can
> >> >> >> see
> >> >> >> its
> >> >> >> me
> >> >> >> that
> >> >> >> want
> >> >> >> is a
> >> >> >> You
> >> >> >> can
> >> >> >> help.
> >> >> >> I
> >> >> >> am
> >> >> >> going crazy!
> >> >> >> Again, Thanks
> >> >> >> RJP
PS - Is there a way or program that will back up my network configuration in
case I need to reload again?
RJP
> RJP
> > Volunteer your CPU to power global research http://www.grid.org/about/ > > > Sign up and join the team
> > > http://www.grid.org/services/teams [...] 8F3AF77CCA > > "RJP" <RJP@discussions.microsoft.com> wrote in message
> > >I
> > > clues?
> > > Thanks again
> > > RJP
> > >> and
> > >> and
> > >> see
> > >> if that works.
> > >> are
> > >> > Thanks
> > >> > RJP
> > >> >> address
> > >> >> have
> > >> >> >bad
> > >> >> >news
> > >> >> > Thanks
> > >> >> > RJP
> > >> >> >> some
> > >> >> >> itself
> > >> >> >> and
> > >> >> >> laptop
> > >> >> >> it
> > >> >> >> can
> > >> >> >> see
> > >> >> >> its
> > >> >> >> me
> > >> >> >> that
> > >> >> >> want
> > >> >> >> is a
> > >> >> >> You
> > >> >> >> can
> > >> >> >> help.
> > >> >> >> I
> > >> >> >> am
> > >> >> >> going crazy!
> > >> >> >> Again, Thanks
> > >> >> >> RJP
> disabled
> transfer
> It
> image
> and
> RJP
Try right click on the folder and select copy then open destination folder,
right click and select paste
