Archived from groups: microsoft.public.windows.networking.wireless (More info?)
Have a main computer using a wireless broadband, trying
to connect using a hub to other computers in house, but
will not connect, yet the wireless one says is connected
ok? Can anyone help?
Using XP go to Control Panel>Network Interfaces>Wireless
Device. On the Advanced Tab click Internet Connection
Sharing.
Make sure you have the Ethernet plugged into the hub.
>-----Original Message-----
>my problem is similar:
>i have an in home network, and i'm trying to get my
windows xp based
>computers to use the network to share an internet
connection. how do i do
>this?
Thanks for answer. Sorry JJ, just want to check I
understand correctly, do you mean from Control Panel >
Network Connections? Then the actual Wireless connection
listed (or the LAN connection)? Do I right click on one
of these, going to 'Properties', unsure where you mean
the 'advanced' tab is, if not here?
>Sharing.
>windows xp based
>>this?
okay found what you were talking about, what if my advanced tab doesn't have
that check box? it only has "Internet Connection Firewall"
> >Sharing.
> >windows xp based
> >>this?
