Hitachi sata 1TB hard drive problem
Last response: in Windows 7
January 25, 2011 6:31:42 PM
Hello,
I can't get the 1 TB sata to format. I can see it on the install but can't get it to partition or format
January 26, 2011 4:58:46 AM
Hi burke1136,
can you see the partitions in the disk management? Or when you likely to format or access the partition, is there any pop-up message? what are they? can the partitions be deleted?
You can download the freeware to have a try and see if it can get your partition.
http://download.cnet.com/Easeus-Partition-Master-Home-E...;1
m
l
