Help - Can't turn off mouse "Snap to"
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I find the mouse snap to feature really annoying. I've
tried to turn it of by unchecking the box in control panel
and by setting the registry Current user, control panel
mouse, snap to value to 0 and rebooting. Neither attempt
worked. What next?
Thanks in advance,
Phil
10 answers Last reply
More about help turn mouse snap
  1. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Did the setting in fact change? Sometimes the user setting are not saved .
    > worked. What next?
    > Thanks in advance,
    > Phil
  2. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Yes, when I check the registry, the setting is 0
    (disabled) but the feature persists.
    >-----Original Message-----
    I've
    panel
    panel
    attempt
    >> worked. What next?
    >> Thanks in advance,
    >> Phil
  3. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    If you have the Intellipoint drivers, try removing and reinstalling mouse?
    > I've
    > panel
    > panel
    > attempt
    >>>worked. What next?
    >>>Thanks in advance,
    >>>Phil
  4. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Nope, that didn't work either. I don't think this is
    worth the frustration, I'll just wait until I re-install
    Windows XP. Surely that will fix it.
    Thanks.
    Phil
    reinstalling mouse?
    >> I've
    >> panel
    >> panel
    >> attempt
    >>>>worked. What next?
    >>>>Thanks in advance,
    >>>>Phil
  5. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Two things on that. First, some graphics card drivers allow for the
    snap-to function and work outside of the Mouse Settings in the Control
    Panel. Check with Hydravision or nView for these options if you have
    either. Others may also have this feature.
    Second, if you plan on reinstalling Windows any time soon, I highly
    suggest waiting a few days as Service Pack 2 will be released very soon.
    This is almost like Windows XP Second Edition they have made so many
    changes. You can slipstream SP2 and then do a clean install that will
    be perfect.
    Nathan McNulty
    > Thanks.
    > Phil
    > reinstalling mouse?
    >>>I've
    >>>panel
    >>>panel
    >>>attempt
    >>>>>worked. What next?
    >>>>>Thanks in advance,
    >>>>>Phil
  6. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    I hadn't run across those yet, good catch!
    > be perfect.
    > Nathan McNulty
    > Phil Banks wrote:
    >> Nope, that didn't work either. I don't think this is worth the
    >> frustration, I'll just wait until I re-install Windows XP. Surely
    >> that will fix it.
    >> Thanks.
    >> Phil
    >> reinstalling mouse?
    >>> Phil Banks wrote:
    >>>> Yes, when I check the registry, the setting is 0 (disabled) but the
    >>>> feature persists.
    >>>> I've
    >>>> panel
    >>>> panel
    >>>> attempt
    >>>>>> worked. What next?
    >>>>>> Thanks in advance,
    >>>>>> Phil
  7. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Since I also have a problem with Internet Explorer that
    was not fixed even by trying to repair Windows XP, the
    only thing left to try is a Windows XP reinstall. But,I
    have to find time to save all of my files to cd's first
    (what a PITA). So, I can wait until SP2 is released. What
    does "Slipstream" mean?
    Phil
    allow for the
    in the Control
    options if you have
    soon, I highly
    released very soon.
    have made so many
    install that will
    >> be perfect.
    >> Nathan McNulty
    worth the
    XP. Surely
    >>> that will fix it.
    >>> Thanks.
    >>> Phil
    and
    >>> reinstalling mouse?
    (disabled) but the
    >>>>> feature persists.
    >>>>> I've
    control
    >>>>> panel
    >>>>> panel
    >>>>> attempt
    >>>>>>> worked. What next?
    >>>>>>> Thanks in advance,
    >>>>>>> Phil
  8. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    HOW TO: Integrate a Service Pack into a Windows 2000 Installation
    http://support.microsoft.com/default.aspx?scid=kb;en-us;271791&Product=win2000
    > Phil
    > allow for the
    > in the Control
    > options if you have
    > soon, I highly
    > released very soon.
    > have made so many
    > install that will
    >>>be perfect.
    >>>Nathan McNulty
    > worth the
    > XP. Surely
    >>>>that will fix it.
    >>>>Thanks.
    >>>>Phil
    > and
    >>>>reinstalling mouse?
    > (disabled) but the
    >>>>>>feature persists.
    >>>>>>I've
    > control
    >>>>>>panel
    >>>>>>panel
    >>>>>>attempt
    >>>>>>>>worked. What next?
    >>>>>>>>Thanks in advance,
    >>>>>>>>Phil
  9. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Bob and Nathan,
    Thanks for your help!
    Phil
    Installation
    What
    >> Phil
    >> allow for the
    Settings
    >> in the Control
    >> options if you have
    >> soon, I highly
    >> released very soon.
    >> have made so many
    >> install that will
    >>>>be perfect.
    >>>>Nathan McNulty
    >> worth the
    Windows
    >> XP. Surely
    >>>>>that will fix it.
    >>>>>Thanks.
    >>>>>Phil
    >> and
    >>>>>reinstalling mouse?
    >> (disabled) but the
    >>>>>>>feature persists.
    >>>>>>>I've
    >> control
    >>>>>>>panel
    >>>>>>>panel
    >>>>>>>attempt
    >>>>>>>>>worked. What next?
    >>>>>>>>>Thanks in advance,
    >>>>>>>>>Phil
  10. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Not a problem. Glad to help. And do note that the link Bob gave you
    will work for XP even though it says 2000 in the link ;)
    I also highly recommend try this method as it is a little more user
    friendly:
    http://www.msfn.org/articles.php?action=show&showarticle=49
    Nathan McNulty
    Phil Banks wrote:
    > Bob and Nathan,
    > Phil
    > Installation
    > What
    >>>Phil
    >>>allow for the
    > Settings
    >>>in the Control
    >>>options if you have
    >>>soon, I highly
    >>>released very soon.
    >>>have made so many
    >>>install that will
    >>>>>be perfect.
    >>>>>Nathan McNulty
    >>>worth the
    > Windows
    >>>XP. Surely
    >>>>>>that will fix it.
    >>>>>>Thanks.
    >>>>>>Phil
    >>>and
    >>>>>>reinstalling mouse?
    >>>(disabled) but the
    >>>>>>>>feature persists.
    >>>>>>>>I've
    >>>control
    >>>>>>>>panel
    >>>>>>>>panel
    >>>>>>>>attempt
    >>>>>>>>>>worked. What next?
    >>>>>>>>>>Thanks in advance,
    >>>>>>>>>>Phil
Control Panel Mice Microsoft Windows XP
