Tom's Hardware > Forum > Computer Peripherals > Printers > Strange HP IIP+ behavior on graphics. Any help?
Forum Computer Peripherals : Printers - Strange HP IIP+ behavior on graphics. Any help?
Archived from groups: comp.periphs.printers (More info?)
Can anybody help me with this problem? I sometimes need to print
simple B&W graphics and Adobe documents using my HP IIP+ printer.
This has posed no problem over the years until recently, when I set
the size to Legal to print a long B&W print, which worked fine also.
Then I set the size back to Letter, and never again has it printed
graphics correctly.
All regular text and word processing programs still print OK. But
from that time on, every Adobe or graphics document prints in the
following wrong way: only the top of the document appears on one page,
abruptly ending and blank from there down, and the bottom of the
document appears on the bottom of the next. page which will be blank
in its upper portion. If you superimpose the two pages, the top and
bottom of the image line up perfectly. And here's the strangest part:
each time I print, the breakpoint is not at the same place on the
image, but is different.
I have tried resetting the printer to its defaults without
improvement. This must be pretty obscure. Does anyone have knowledge
about this? Thank you! RD2
Sponsored Links
In message <40a79d97.14977427@news.nls.net>, RD2 <void@en.com> writes
>graphics correctly.
Your printer is running out of memory, IIRC the IIP only came with .5
meg memory so a graphic will often be more than that so it takes as much
info in as it can, prints that then fills up the memory again.
Timothy Lee http://www.wightproperty.com
tlatwightpropertydotcom
Reply to Anonymous
Mr. Lee,
That sounded like a good suggestion, so to test it I made a graphic
that is only one vertical line - pretty small size - and it still did
the same problem.
Plus, the printer has had no problem all these years until now, so can
you you think of another possibility here?
Thank you for taking the time to reply. RD2
On Tue, 18 May 2004 09:04:28 +0100, Timothy Lee <me@privacy.net>
>>graphics correctly.
Reply to Anonymous
In message <40a9f6f2.1020783@news.nls.net>, RD2 <void@en.com> writes
>Mr. Lee,
>the same problem.
If its not the memory I don't know what to suggest, have you tried
fiddling with advanced settings for memory handling for graphics in the
Windows control panel printer settings?
Reply to Anonymous
- 0 +
I've just spent about a week chasing a fault in my laserjet IIIP which I
think has similar
mechanics. My problem was an extra page being inserted between
multiple-page prints from
the optional sheet feeder. But it was ok from the front sheet feeder. The
cause could well
apply to your laserjet IIp.
There are two solenoids (look like relays without contact sets) in the sheet
feeder and one
next to the fuser inside the opening front on the right hand side. They
control clutches.
There is a felt pad under the armature stop of each solenoid. After many
years these
disintegrate and leave just the adhesive backing, which causes the solenoid
to stick and
mucks up the paper feed timing.
Remove the armatures, clean off the sticky stuff and replace with self
adhesive felt or
whatever else you can find. It fixed mine.
I might add I changed almost every opto sensor, roller and removeable part
(I had a non working
spare printer) before I found a clue on the internet. I was very pleased to
get the hint, I
had almost given up. It was an obvious thing I overlooked.
Even if it's not the solution to your current problem, it probably will be
one eventually. I'd be interested to
hear if it fixes your problem.
Good luck
Barry
"Timothy Lee" <me@privacy.net> wrote in message
news:snz6rSCTDiqAFwsL@townvillage.eclipse.co.uk...
> >Mr. Lee,
> >the same problem.
Reply to Baz
Baz,
Even though I wasnt convinced that my problem was the same as yours
(because text pages print normally) I tried your suggestion.
Unfortunately, my problem persists. Any other thoughts?
RD2
>think has similar
>cause could well
>feeder and one
>control clutches.
>years these
>to stick and
>adhesive felt or
>get the hint, I
>Good luck
>Barry
>> >Mr. Lee,
>> >the same problem.
Reply to Anonymous
- 0 +
Try going into your printer driver setting and make sure
paper size is correct. possible
"RD2" <void@en.com> wrote in message news:40b0071d.518888@news.nls.net...
> Baz,
> RD2
> >think has similar
The
> >cause could well
sheet
> >feeder and one
> >control clutches.
> >years these
solenoid
> >to stick and
> >adhesive felt or
part
to
> >get the hint, I
be
> >Good luck
> >Barry
> >> >Mr. Lee,
> >> >the same problem.
Reply to yoyo
Yo Yo,
Yes, the paper size is set correctly. Any idea why the problem does
not occur when printing text, only graphics or Adobe reader files?
Thanks for thinking about it and for making a suggestion!
RD2
On Tue, 25 May 2004 17:42:39 -0400, "YoYo" <YoYo@none.of
>> Baz,
>> RD2
>> >think has similar
>The
>> >cause could well
>sheet
>> >feeder and one
>> >control clutches.
>> >years these
>solenoid
>> >to stick and
>> >adhesive felt or
>part
>to
>> >get the hint, I
>be
>> >Good luck
>> >Barry
>> >> >Mr. Lee,
>> >> >the same problem.
Reply to Anonymous
- 0 +
I guess your first logical step is to try the printer on another computer
(and just to be certain another printer on your computer). That way at
least you'll know if you're chasing a printer fault or computer (software)
fault. Although on the face of it, it looks like a software problem as it
occurred after you changed your settings.
Sorry about the unnecessary hardware suggestion ealier, I should have read
your message more closely (that is it printed ok with text only). But as I
said you'll probably need to do it sooner or later anyway.
By the way, when you go to printer test (off line, Alt/Test) and it prints
the two test pages, do they come out ok? If not that would immediately
point to a printer problem. (This may have already been suggested but the
previous posts are missing at this date)
Barry
"RD2" <void@en.com> wrote in message news:40b6bbf4.1052410@news.nls.net...
> Yo Yo,
> RD2
> >> Baz,
> >> RD2
I
> >> >think has similar
> >The
> >> >cause could well
> >sheet
> >> >feeder and one
They
> >> >control clutches.
many
> >> >years these
> >solenoid
> >> >to stick and
> >> >adhesive felt or
> >part
pleased
> >to
> >> >get the hint, I
will
> >be
> >> >Good luck
> >> >Barry
> >> >> >Mr. Lee,
did
> >> >> >the same problem.
can
the
Reply to Baz
memory/ printer memory
> graphics correctly.
Reply to Anonymous
>> graphics correctly.
>> image, but is different. I have tried resetting the printer to its
>> defaults without
I'd confirm that both the printer is set to 8.5x11 (thru the LCD panel)
and the software, (Windows I assume) is set to the same.
Reply to Anonymous
There are 1145 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
