G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I've just built a system using Asus A8N-SLI Deluxe, everything appear to
be working fine except for DHCP.
I have other computers (all Asus motherboards), and the get their IP
addresses from a Netgear DG834G router/firewall/DHCP server.
My other system is given a IP address of 192.168.0.X with a netmask of
255.255.255.0, and this connects to the Internet with no problems at all .
My new system based on A8N-SLI Deluxe, however, appears to get an
address of 196.254.X.X, with a netmask of 255.255.0.0.
This occurs with both the onboard interfaces, and even a NIC on a
plugged in PCI card (and USB NIC), these all get similar addresses,
beginning 196.254.X.X
If I manually config one of the interfaces to 192.168.0.10 say, the I
can ping the router, but can't connect to the Internet.
I was wondering if anyone else had observed these problems with this
board and DHCP?
The system board has BIOS 1003. All of the other system components were
working fine on an A8V Deluxe, which I removed to fit the A8N-SLI Deluxe
board, the A8V Deluxe worked fine with the Netgear. It's only since
fitting this board that these problems started.
The system was installed with fresh install of Windows XP Pro.
Please Reply to group.
board and DHCP?
