Can not burn CDR anymore - Insert empty disc problem
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Hello,
For some days now, I can not burn CDRs. The problem is
that any software I use is telling me to insert an empty
disc even if there is one in the drive. Eject and retry
does not help
The drive is a DVR-RW drive (HL-DT-ST DVD-RW GWA-4040N)
on an Acer Ferrari 3000 Laptop.
By searching on the web, it seems it is a LG Drive.
Firmware are up to date (I didn't change anything).
I'm using Windows XP Pro SP1a with all critical updates.
I tested it with Nero 6.3.1.7, blindwrite but in fact it
seems to be a windows problem as in the explorer the new
disc is also not recognised.
I searched fro solutions on the web and could find a lot
of people with the same problem (not necessary with the
same drive) but without solutions.
I already tried to enable/disable the "Enable CD
recording on this drive" (Recording tab of the Drive
properties) and it did not help.
I also checked that I have the latest ASPI drivers.
Now, the wired thing. Sometimes, but only sometimes,
after a reboot and a quite long time before starting
again the machine (some hours), then I can burn ONE CDR,
but only ONE. This is burned correctly without errors.
I forget to mention that I can burn DVD (+ and -) and CD-
RW without problem.
Hope somebody can help me on this one
Thanks a lot in advance for your suggestions/solutions
Didier
5 answers Last reply
More about burn anymore insert empty disc problem
  1. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Could try reading this:
    http://support.microsoft.com/default.aspx?scid=kb;EN-US;324129
    Sounds really odd. It sounds like the drive is just failing to read the
    beginning of the disk to find out what type it is, yet it works for
    everything else.
    Nathan McNulty
    Didier Eychenne wrote:
    > Hello,
    > does not help
    > RW without problem.
    > Didier
  2. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Thank you for your help Nathan but I tried these
    suggestions already.
    I'll continue searching on the web for a solution
    Didier
    >-----Original Message-----
    US;324129
    failing to read the
    it works for
    >everything else.
    >Nathan McNulty
    >> Hello,
    empty
    retry
    >> does not help
    4040N)
    updates.
    it
    new
    lot
    the
    CDR,
    CD-
    >> RW without problem.
    >> Didier
  3. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    An acceptable approach to this is if you can't find a fix is to do a
    repair installation. If that doesn't help, you can always try a clean
    install of XP. Just make sure to backup all of your data before doing
    either (especially the latter).
    To Repair:
    Boot off the XP CD, choose Install, it will find the existing
    installation of XP and offer to repair it, press R to repair, and it
    will do everything from there.
    To Clean Install:
    Boot off the XP CD, choose Install, format the drive (this will erase
    all of your data and NTFS (Quick) is suggested), then install XP. This
    will require all your programs be reinstalled :(
    Nathan McNulty
    > Didier
    > US;324129
    > failing to read the
    > it works for
    >>everything else.
    >>Nathan McNulty
    >>>Hello,
    > empty
    > retry
    >>>does not help
    > 4040N)
    > updates.
    > it
    > new
    > lot
    > the
    > CDR,
    > CD-
    >>>RW without problem.
    >>>Didier
  4. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    On Thu, 5 Aug 2004 05:04:20 -0700, "Didier Eychenne"
    <bill_gates0@nospam_hotmail.com> wrote:
    >Hello,
    Anything change recently?...any software installs?...software
    updates?...new virus definitions?...and Norton stuff?...changed brands
    of cd's? Try a new, better brand of cd's. And make sure the cd isn't
    put in upside down (happens a lot on non-printed cd's).
    >The problem is
    >does not help
    Can you read cd's okay?...both retail and burned?
    Maybe the drive is just dirty...or goin' bad. Getting some good
    quality cd's may help.
    Is the drive itself recognized in explorer?
    With what program?
    Good luck...let us know.
    Have a nice week...
    Trent
    What do you call a smart blonde?
    A golden retriever.
  5. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Hello, Thanks both of you for your suggestions.
    See after my comments to your questions
    The only things that helped a little bit was to deinstall
    the drive (in windows not physically) and reinstall it.
    Now I can always burn ONE CD after reboot, but still only
    one.
    Didier
    >>Hello,
    sure the cd isn't
    no new installation, virus definitions, yes, of course
    (everyday ?!?)
    I tried with several cds with the same result. Verbatim,
    TDK, Maxell, and noname cds. Same result.
    Again. I can burn one CD only, after nothing, I need to
    reboot and sometimes it works again.
    Remember that I can burn CR-RW, DVD without problem
    Playing CDs, DVDs always works
    It is only that a blank CD is not recognize to start to
    burn (And yes I did not try to put more then 700 MB if it
    is a 700 MB CDR...saw this as suggestion in some post
    here related to the same problem (Re: sony cd-rw quit
    working for no apparent reason))
    >>The problem is
    empty
    >>does not help
    yes, dvds also
    some good
    verbatim is a quality cd I hope. I will try to clena the
    drive but this does not explain why I can burn CD-RW or
    DVDs
    it
    new
    Yes
    lot
    CDR,
    >With what program?
    All of them, Nero 6.3.1.7, Blinwrite,
    >Have a nice week...
    >Trent
    >A golden retriever.
Burner Windows XP
