G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I purchased an ASUS A7V8X-X as a replacement motherboard. I am trying
to connect front audio panel mounted in a 5.25 bay insert plate and use
the front panel audio connectors that are on the motherboard. I am
having some difficulties in establishing the correct pin outs to
activate the front panel audio connections without affecting the
motherboard's rear audio connectors. I want the front panel audio
primarily for connecting up headphones to listen to music.
The front panel audio panel has a 6 channel audio interface cable with
the following pins to be connected to the motherboard (the pins are
individually terminated):
Mic-R
Mic-L
Front-R
Front-L
Rear-R
Rear-L
Gnd
Bass
Center
The front panel has 4 audio jacks as follows:
Mic IN
Front Out
Rear Out
Cen/Bass
I would simply like to activate the Front Out audio jack to hook up a
set of head phones.
The A7V8X-X motherboard front audio pin connector has 9 pins identified
as follows:
Mic2
MicPwr
Line Out_R
NC
Line Out_L
AGND
+5VA
BLine Out_R
(no pin)
Bline Out_L
The default connections on the motherboard as received have Line Out_R
jumpered to BLine Out_R and Line Out_L jumpered to Bline Out_L.
Removal of either of these jumpers kills the sound on one of the stereo
channels from the rear audio outputs on the motherboard without any
front panel connections being made. Removing both kills the sound on
both stereo channels from the rear audio outputs on the motherboard
without any front panel connections being made. I have a set of stereo
speakers and separate sub-woofer connected to the rear panel audio out
jack.
I attempted to make the following front panel audio connections to the
mother board front panel audio connection>
Front-R to Line Out_R
Front-L to Line Out_L
Rear-R to BLine Out_R
Rear-L to Bline Out_L
Gnd to AGND
The SoundMax audio configuration program was set to "Stereo
Speakers"
With this set up I expected to get audio from headphones connected to
either the front panel FRONT OUT or REAR OUT audio jacks. I only
received a single channel on either, no stereo.
Can you tell me what the pin-out connections should be so that I can
get 2 channel output on the front audio panel FRONT OUT or REAR OUT
audio jacks? Thank you for your assistance.
DGD
Mic-R
Mic-L
Front-R
Front-L
Rear-R
Rear-L
Gnd
Bass
Center
Mic IN
Front Out
Rear Out
Cen/Bass
set of head phones.
as follows:
Mic2
MicPwr
Line Out_R
NC
Line Out_L
AGND
+5VA
BLine Out_R
(no pin)
Bline Out_L
jack.
Gnd to AGND
Speakers"
DGD
