G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I have a new A8V Deluxe with A64 3500+ running stock speeds/fan/hs.
Nothing fancy. For the heck of it I ran MBM5. I chose the only Asus A8V
mobo from the list, the Deluxe Wireless Edition. I don't have the wireless
feature but I assumed it was all the same sensors.
MBM5 reports my CPU temp as between 18 and 24C depending on what I am
doing. That seemed ridiculously low so I became suspicious. MBM5 uses
winbond 1 for CPU temp. Whatever the heck that means.
Anyway, I installed Asus' PC Probe to compare. It reports the CPU temp
between 40 and 50 depending on what I am doing. HUGE difference. I don't
know what sensor Asus PC Probe uses but I'm sure it's the RIGHT one. I
started farting around with MBM5's settings and found that if I told it to
use winbond 2 for the CPU temp it matched exactly with Asus PC Probe.
So, unless someone knows something I don't know, don't rely on MBM5 with
the Asus A8V. I think it's wrong.
