G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
The System:
P4T533 Asus Mobo Rev 1.03 BIOS 1006 (with optional USB 2.0 Port)
512 MB Samsung 232-pin RDRAM
Intel P4 2.53 Ghz CPU
PNY/Verto Ti4600 128MB AGP Video card
Soundblaster Audigy Platinum soundcard
Diamond v.92 Internal Modem/FAX card
Linksys 10/100 ethernet card
430W PS
Internal IDE Drives:
Pri Mas: WD 40GB (Boot drive - Jumpered as Cable Select) +
Pri Slv: Not Used
Sec Mas: LG-4040 DVD Burner
Sec Slv: LG-4160 DVD Burner
RAID 1+0: WD 250GB (ID:0) Jumpered as Cable Select +
RAID 1+0: WD 250GB (ID:1) Jumpered as Cable Select +
+ Note: These drives are mounted in ViPower Removable Racks
External USB 2.0 Drives:
WD 120GB in Bytecc External Enclosure (Jumpered as Master)*
*Note: Both are plugged into the Mobo's Optional USB2.0 Port)
Additional Devices:
Belkin 7-Port USB 2.0 Hub
HP 895 Printer (Using USB)
Visioneer 8100 Scanner (Using USB)
Linksys WRT54G Router
Linksys PSUS4 Print Server
Operation System:
Windows 2000 Professional with Service Pack 4
Okay... Simply put, no matter what I do, I cannot get USB 2.0
throughput. It is roughly equal to USB 1.1 throughput. A 43MB file
takes about 33 seconds to transfer to either of the external drives,
whereas my friend's older, slower (400 Mhz FSB - 1.6Ghz P4) copies the
same file to his external USB drives in about 4 seconds!
Device Manager shows an Asustek Enhanced USB Host Controller, and
other USB Host Controllers, but nowhere does it mention USB 2.0 at
all. One utility (I forget which one) reported no USB 2.0 devices on
the system.
Calls to Asus Tech Support haven't helped. One tech suggested taking
the Mobo out and laying it on cardboard or other non-electrically
conductive surface to make sure the board wasn't touching and/or
shorting on the case. That didn't help. Another tech suggested getting
a USB2.0 PCI card, which I did. Guess what? That didn't help
either!!!
Took one of the external drives and connected it to a computer with a
known working USB 2.0 port and it worked as it should so I know the
drives and enclosures are good.
Had the system stripped down to the boot drive and one external. No
joy. Wiped the boot drive and installed XP Pro. No joy.
So, my questions are these:
Is there an inherent problem with this Mobo's implementation of USB
2.0 and, if so, is there a fix?
Is there any way to turn off USB 2.0 on the Mobo? When I had the PCI
USB 2.0 card in, USB was turned off in the BIOS, and a jumper on the
Mobo was moved, but the ports still seemed to be working.
Has anyone else had this problem? Did you solve it? If so, how?
Any and all help is greatly appreciated.
Thank you.
-sorry for the lengthy post.
The System:
430W PS
Pri Slv: Not Used
Additional Devices:
Operation System:
the system.
either!!!
Thank you.
