Tom's Hardware > Forum > Motherboards & Memory > Asus > Com2 enabling problem on P4P800 Deluxe
Forum Motherboards & Memory : Asus - Com2 enabling problem on P4P800 Deluxe
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Having problems enabling COM2.
I've done it in Bios and it shows on WinXP Device Manager, but my
serial devices do not work on it, only on COM1.
Any advice?
Sponsored Links
In article <31mn21h2bise2ce61kvh4s90r4pngnfcle@4ax.com>, f13dfx
> Any advice?
http://abxzone.com/forums/showthre [...] 4p800+com2
What kind of adapter are you using ? There are two different
pinouts for the adapter. Maybe your adapter is not an "Intel-Everex"
adapter ? I would expect all boards in the P4P800/P4C800 family
to be similar, when it comes to RS232. This guy figured out the
pinout the hard way.
http://home.att.net/~Tom.Horsley/p4c800e.html
Paul
Reply to Paul
Paul,
Thank you so much!!!
I just took my soldering iron out and resoldered the wires to the
pinout shown on the link and voila!
Worked like a charm.
Now I wonder what I should do to that 2-serial port pci card I won on
eBay :) I guess I'll now have 4 com ports :)
Thanks again!
>> Any advice?
>http://abxzone.com/forums/showthread.php?t=53184&highlight=p4p800+com2
> Paul
Reply to Anonymous
There are 907 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
