G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I've just built my sister a new P4P800 SE with a new 3E GHz Pent 4 CPU. I
use the packaged Intel fan and heat exchanger with the gummy heat exchange
compound. The system got too hot ( 78.5 degrees C or 178 degrees F almost
twice my own temps on my computer-- I get 100 degrees F), but ****I did get
a Bios**---- never got to the point of formatting and setting up Win XP. I
took the board out, and cleaned up the chip and the heat exchanger; then, I
applied good heat exchange paste I've used before. I set the computer
backup just like it was before. One ATA hard drive, a generic CD ROM, a
floppy, and a AGP video board ( simple setup). I checked and rechecked the
cords and plugs. The fans don't turn -- there is no action -- damn. All I
get is the green standyby power light inside the case when I turn the
computer on. Anyone have any ideas what I might try next? Thanks for any
help!
Sincerely --- Randy O
help!
