Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
My son has an Asus a7n8x-deluxe with a Athlon 2500 cpu, 1 gig of ram, SB
live audio and winTV tuner card. The power supply is an Antec SL350 (350
watt). The system also has five 12V fans, two 80 gig HD and a pair of
CDROMs (infrequently used). Video card is an ATI 9800.
This system has been running without a hitch for almost two years. But,
in the last couple of weeks the system has started acting flacky;
noise/distortion on the TV audio and some stability/boot problems.
Because of this he brought the system home over the weekend to try and
determine the cause of the problem. In inspecting the system I found
nothing wrong until I checked the motherboard 20 pin power connection.
After unplugging the connector, I found the white plastic around all
four +5V pins significantly scorched. This is obviously not good. These
connections are overheating due to either excessive current draw,
corrosion (high resistence), or what? I'm trying to understand what can
cause this to happen. I believe the PCI slots are powered by the +5V
rail. Inspection of the two PCI cards (tuner and SB Live) didn't reveal
any obvious signs of a failed components. When I removed the MB and
looked it over, other than the discolored power connector socket there
were no obvious signs of overheated parts. Of course power regulators
and such can be bad without visible signs, but I kind of expected a high
current condition to leave some trace on the MB itself.
So far I replaced the power supply with a no-name 350w that I had on
hand and cleaned the light layer of dust off the motherboard and case.
For the last two days the system seems to working. But, for how long?
With the "new" power supply Motherboad Monitor shows the +5V supply
ranging from 4.78V to 4.88 V, perhaps a little on the low sigh but still
with the 5% tolerance for +5V. The 3.3V and 12V lines are fine. System
temperature doesn't exceed 50 deg C for the CPU. I did see one transient
event on the processor core voltage where it dipped to 0.7v from the
normal ~1.6V. This was a bit disturbing too. Does this point to a
voltage regulation problem on the MB?
My questions are:
What else on the MB is powered from the +5V supply? (I know the +5V goes
to the two HD installed on the system, but non of the 5V pins elsewhere
show any signs of overheating) I believe the CPU is powered by the 3.3V
rail(which showed no signs of distress).
Is the +5V indeed regulated via circuitry on the MB? If so, could a
failure on the MB cause an excessive current draw, but only on the +5V?
Before I/he just buys a new MB, I would like to narrow down (if
possible) the problem to one component. In the past I have played the
parts change game and ended up replacing parts that were perfectly good
(e.g., the spare 350W power supply).
My questions are:
