Archived from groups: alt.comp.periphs.mainboard.asus (
More info?)
On Thu, 17 Mar 2005 03:03:53 -0800, cain@nospam.com wrote:
> On Wed, 16 Mar 2005 14:05:18 GMT, signmeuptoo
> <signmeuptoo_no_spam@earthlink.net> wrote:
>>Hey guys,
>>What heat sink are *you* using with your system? What CPU fan? What is
>>your motherboard and CPU?
>>Why did you choose what you did?
>>What kind of temps are you getting, and what are you using to monitor those
>>temps?
> I'm using the Thermalright SLK-948U (a big copper thing) with an amd64
> 2800 and a high speed 92mm Panaflow fan rolled down in speed with the
> motherboard fan controller. Idle speeds are mid 30s with all fans
> running slow. I wouldn't turn up the Panaflow as it gets quite loud.
> I have a ATI 9800Pro heating things up in there too.
> Even turned down in speed, the Panaflow is pretty noisy spectrum wise.
> Next time I'd get the Thermalright heatsink that supports a 120mm fan
> as they are quietest when turned down. (Got two of them as case fans
> in another box).
Yeah, that is why I plan on getting the Thermalright XP-120. It is
supposed to be an almost phenomenal heatsink. I just got my fan that I
will use on it from UPS today, and Enermax UC-12FAB-B. They aren't too
easy to find as a lot of places have stopped carrying them. It has a
variable fan speed control extension on it. It is pretty quiet, and not
too loud at full speed (2300 RPM) but it moves a lot of air, I forget the
specs though.
> Was thinking about water cooling once, but these big Thermalright
> heatsinks with AMD64 cores do the job.
> Glad AMD came out with such a great product when Intel was hitting
> rock bottom and just grinding to a halt.
