Archived from groups: alt.comp.periphs.mainboard.asus,free.it.hardware.asus (More info?)
Hi, I have update my P4P800-SE BIOS to 1.008 release (the last one).
Now I'm not able to print via parallel port, looking into ths BIOS setting I
have found
PARALLEL PORT ADDRESS DISABLED
I have NEVER done this change........ anyway, I have reset it to 378
(default) but the system does not find the printer (by the way it works fine
via USB cable),
I need parallel port because I have all USB port working with other devices.
Cheers, yes the chip is supported and have tried the latest to the 2
previous bio's, still no avail
"Alb" <alb460@nospam.virgilio.it> wrote in message
news:0S%_d.675854$b5.30694500@news3.tin.it...
> I have found
> fine via USB cable),
> devices.
> Any idea ?
> Thanks
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Yes but it does not WORK also after the reset ...
" -" <xvvvz@hotmail.com> ha scritto nel messaggio
news:wh1%d.633$Vi3.314@newsread3.news.atl.earthlink.net...
> FWIW, every time I have updated my BIOS on this board I have had to go
> into the BIOS and re-enable the printer port.
> Doug
My printer is an HP 920C I have always used it via parallel port
"Mistoffolees" <mistyfac01@danang.rvn> ha scritto nel messaggio
news:113q8nfda91c666@news.supernews.com...
> Alb wrote:
>> Yes but it does not WORK also after the reset ... >>
> What make of printer? And it does allow for a parallel
> port connection? Some USB printers do not have this
> capability.
OK. Go back into bios setup and verify that the LPT
port is set for either bi-directional, EPP or ECP mode.
When updating the bios, it might have reverted the
setting to Normal.
news:113qb2to3k6iha1@news.supernews.com...
> setting to Normal.
Yes it was set to NORMAL, I have set it to a different values but nothif
change
Thank you a lot anyway .
> setting to Normal.
In article <U9m%d.678909$b5.30850954@news3.tin.it>, "Alb"
> change
Have you tried clearing the CMOS ?
First, unplug the computer. Then, follow the procedure
in the manual in section 2.6 "Jumpers".
My suspicion would be, there is a data mismatch between
the contents of CMOS and the new BIOS. Clearing the
CMOS might help.
Paul
> > setting to Normal.
In fact I have had an error during BIOS updateì, if I remneber well it was a
CMOS error, I'll try in few days
Tnx
Alberto
"Paul" <nospam@needed.com> ha scritto nel messaggio
news:nospam-2003052120240001@192.168.1.178...
>> change
> CMOS might help.
> Paul
>> > setting to Normal.
I have just cleared CMOS, but the printer is not working via parallel port
"Alb" <alb460@nospam.virgilio.it> ha scritto nel messaggio
news:EjG%d.1095063$35.40735960@news4.tin.it...
> a CMOS error, I'll try in few days
> Tnx
> Alberto
>>> change
>> CMOS might help.
>> Paul
