G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
System crash, when ethernet trafic grows, in exemple if I start emule or
copy files from other PC in my net. But system works normaly when
I use Internet Explorer or Outoolk Express, Xnews, etc.
When system hangs, I only can press reset button, no Ctrl-Alt-Del works
or
system logs can be found.
System:
A8V de luxe R2.0 with BIOS 1009.
AMD 3500 64 bit
2 512MB sticks DDR400 in Dual-channel mode.
2 HD Maxtor 160 Gb. in RAID-0 at Promise controler
Asus V9570 Vga card
WinXp pro SP2 installed from a CD with SP2+Promise+Via drivers.
I tried:
- Monitoring CPU temperature with Asus PC Probe V2.23.03
- Disable ethernet motherboard conection from Bios
and punch a Intel PCI ethernet card. Problem continues.
- Installing drivers for AMD 64 from AMD web.
- Disable completely Windows firewall.
- Change this registry key:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters]
adding
"TcpNumConnections"=dword:0077fffe
Please, any ideas is welcome...
Thanks
or
System:
AMD 3500 64 bit
Asus V9570 Vga card
I tried:
adding
Thanks
