Tom's Hardware Forums » Motherboards & Memory » Asus » P2B-DS USB problem in WinXP
Word :   Username :
Bottom
Author
 Thread : P2B-DS USB problem in WinXP
More Information
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I have an old Asus P2B-DS, working fine. I installed winxp sp2 on it.
Everything works except the USB driver in the Device Manager isn't
working. I looked on the asus site and there doesn't seem to be a
special USB driver in the p2b-ds driver list. Am I the only one with
this problem?
The device manager lists the driver as:
Intel(r) 82371AB/EB PCI to USB Universal Host Controller
That's kind of odd because the USB is onboard on the p2b-ds.
Related Product
Profile: stranger
More Information
checked it with mine and that is the same listing I have, except I am not
running
sp2 on it.
have you tried removing it from the device manager and rebooting and see if
windows redetects it and installs the proper driver.
<dterrors@hotmail.com> wrote in message
news:1111988059.070446.274780@z14g2000cwz.googlegroups.com...
> this problem?
More Information
> this problem?
Not odd, as expected - 82371AB is one of the 440BX chipset devices. You
should also have a 'USB Root Hub' device listed.
P2B-DS onboard USB ports work fine here under XP SP2 using default
drivers. What does Device Manager say about device status when you
double-click it?
As BigJim suggests, uninstalling the USB devices and rebooting is a
logical first step. Make note of any errors XP reports when re-detecting
the USB devices.
HTH
P2B
More Information
On 27 Mar 2005 21:34:19 -0800, in <alt.comp.periphs.mainboard.asus>,
> working.
[snip]
Apparently, that is a common problem on earlier-revision P2B-series boards.
Per <http://www.linux-usb.org/FAQ.html>:
| Q: My Asus motherboard doesn't work, or works with only one device
| A: Some early Asus P2B-DS and P2B-D motherboards have a design flaw
| that means that the chipset doesn't get sufficient voltage. I suggest
| returning the motherboard. Alternatively, check the Asus website at
| http://www.asus.com.tw/supportnews [...] 17695.html
| for a hardware solution.
> this problem?
[snip]
From what I gather, it's not a driver problem; it's (at least primarily) a
hardware problem. There is supposedly a home-brew fix described at
<http://www.asus.com.tw/supportnews/english/mainboard/p2bx/17695.html>; but I
cannot raise that page ATM.
What makes you think that's "odd"? The P2B-series boards are based on the
Intel 440BX chipset.
Jay T. Blocksom
Appropriate Technology, Inc.
usenet02[at]appropriate-tech.net
"They that can give up essential liberty to obtain a little temporary
safety deserve neither liberty nor safety."
-- Benjamin Franklin, Historical Review of Pennsylvania, 1759.
Unsolicited advertising sent to this domain is expressly prohibited under
47 USC S227 and State Law. Violators are subject to prosecution.
More Information
> > working.
> [snip]
The FAQ is misleading. The USB hardware issue on *very* early P2B-D/DS
boards (revision 1.03 and earlier only) is that they provide
insufficient current to bus-powered USB devices for reliable operation.
This should not affect the chipset, or Window's ability to detect the
chipset and install drivers - although it might make sense to disconnect
USB devices during OS installation or re-detection attempts.
The fix (as implemented by Asus on revision 1.04 and later boards) is to
replace R112 with a 0 ohm resistor. An alternative is to use an
independently powered hub as the only directly-connected USB device.
P2B
> > this problem?
> [snip]
Google Ads
News
ATI Catalyst drivers have a problem
Published on August 27, 2004
ATI has a problem in the latest Catalyst drivers. Read more
Nvidia Contract Makers In Taiwan Low-key Over Defective Chip Reports
Published on July 07, 2008
Nvidia's Taiwan-based graphics chip contract makers are being low-key after the US chip designer informed investors on July 3 that will take a charge of US$150-$200 million related to expenses stemming from issues discovered with die/packaging materials used in previous generation notebook products. Read more
XP Service Pack 3 Kills AMD Machines
Published on May 09, 2008
Windows XP Service Pack 3 finally arrived to our computers this week… And is now killing AMD machines, according to Jesper Johansson, former program manager for security policy at Microsoft. Read more
CES 2007: CarMD finds the problem, then tells you what parts and labor should cost
Published on January 09, 2007
Two crappy things in this world: (1) Your car breaking down and you not knowing why; and (2) going to get it fixed and being charged an arm, a leg and some other essential regions in order to get it fixed. Read more
Latest Reviews & Articles
Four GeForce 9600 GT Cards Compared
Published on September 26, 2008
Manufacturers really love the first Geforce 9. The graphic chip is fast, the cards are inexpensive, and some retailers offer more than ten variations. Read more
Maxtor's Shared Storage Does NAS At Home
Published on September 25, 2008
What do you do with all the data you collect at home? Network attached storage is the solution. We test Maxtor's Shared Storage II and find that it is also suitable for use in small businesses. Read more
SLI & Centrino 2: Gaming Laptops Battle
Published on September 24, 2008
Take four gaming laptops. Arm two of them with SLI and make the others Centrino 2-compatible. You're looking at a high-end collection of the latest mobile technology battling it out for benchmark supremacy and your hard-earned dollars. Read more
1,000 GB: Three Samsung TB Drives
Published on September 23, 2008
Storage vendors split the desktop hard drive market into performance, mainstream, and energy-efficient products. We looked at Samsung’s Spinpoint F, the RAID version and the EcoGreen F to discover how a 1,000 GB drive differs from another. Read more
