Tom's Hardware > Forum > Smartphones & PDAs > Windows Mobile > SD card error !!! Please help
Forum Smartphones & PDAs : Windows Mobile - SD card error !!! Please help
Archived from groups: microsoft.public.pocketpc (More info?)
I have a Kingston 512mb SD card. I have been using this card for some months
to store files and programmes without issue until this week.
Yesterday I tried to access an MP3 file on my pocket PC but it has
disappeared none of my mp3 or wmv files appear. I checked using the file
explorer and non of my files, folders or programmes appear. Instead there is
a 0kb file which is called "ignore my docs". I deleted this hoping that it
would clear the problem but no luck.
I have tried viewing the files on my desktop using a card reader - again
none of the files appear but my desktop tells me the card has 488mb memory
in use so they must be there right ?
I have run the error check app on the card from my desktop and no problems
are reported. I have also run a virus check and there are no issues.
Can anyone help ?
Thanks
Sponsored Links
Would it be possible that all the files in the root of
your card are marked as 'Invisible' and that you need
to turn on Show All Files? (Tap-Hold on a white space
on the PPC)
You might also want to check this with a card reader
on your desktop computer.
~S.
"shaun" <s2@stuarts0.demon.co.uk> wrote in
news:eFuYUiuWEHA.3944@tk2msftngp13.phx.gbl:
> months to store files and programmes without issue until this week.
> file explorer and non of my files, folders or programmes appear. Instead
> there is a 0kb file which is called "ignore my docs". I deleted this
> hoping that it would clear the problem but no luck.
> memory in use so they must be there right ?
> problems are reported. I have also run a virus check and there are no
> issues.
> Can anyone help ?
> Thanks
ACE!!! a.k.a. ~S.
OS. Osaris / Psion 5mx
iPAQ 5550 / Nokia 6310
HTTP://www.xarane.com
Reply to Anonymous
There are 929 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
