A7V880: onboard audio and sound card
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Hi.
I'm having a problem with the Asus A7V880 mobo I bought recently. I was
happy to find that it includes an onboard sound card (6-channel SoundMAX
digital audio AC'97 complaint) supporting the connection of audio jacks on
the chassis. However, I also found out that the new mobo no longer has a
game port on the back: it is only available on the board and can be used
only with a special cable that I don't have.
Until now; I have been using a old Creative SoundBlaster PCI 512 for both
4-channel audio and game port; the downside is that it does not support the
connection of chassis audio ports.
Now the question: is it possible to use my PCI audio card AND the onboard
audio at the same time? Of course in Windows I would set the onboard audio
as default hardware to play sounds and use the PCI card only for its game
port.
I have tried, but when my PCI audio card is connected the mobo somehow
recognizes it and the OS does not detect the presence of the onboard audio,
even while it is enabled in the BIOS.
Is there a solution?
Thank you in adavance.
Merak
18 answers Last reply
More about a7v880 onboard audio sound card
  1. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    Wht don't you buy a USB compatible Joystick? They work much better than
    using a joystick port anyways.
    "Merak" <me@anywhere.net> wrote in message
    news:WWW5e.48990$kC3.10966@tornado.fastwebnet.it...
    > Hi.
    the
    > port.
    audio,
    > Merak
  2. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    I know it would be better, but if I'm asking here I obviously already
    considered that option. The problem is that I own many controllers,
    including two expensive Sidewinder game pads (and I use them both) and I'm
    going to try all the other options before re-buying them.
  3. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    Missed the OP, but it sounds like you want to use the old style joystick
    connectors on a machine without them.
    If so have you tried instaling a card with a joystick port on it, then
    disabling the other functions of the card (as usually they are sound cards).
    I'm not to pleased with SoundMAX, apart from not sounding that great, I need
    to reboot everytime I change my speaker configuration from headphones to
    5.1. Seems amateurish to me
    If I haven't described your problem, just ignore me ....
    news:U8q6e.51044$kC3.17396@tornado.fastwebnet.it...
  4. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    > cards).
    I tried disabling the driver in Device Manager, but the onboard chip remain
    undetected until I physically unplug the card. One thing I didn't check is
    wether there are jumpers on the card, but I remember not.
    > need to reboot everytime I change my speaker configuration from headphones
    > to 5.1. Seems amateurish to me
    I don't need a professional audio system: the main reason I would like to
    use the onboard audio is to use the front panel connectors.
    Merak
  5. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    Merak wrote:
    > Hi.
    Obviously this cable, with a back-panel connector would be ideal... can
    you describe the connector? How many pins by how many pins and are any
    missing?
    e.g, many USB connectors look like this (fixed width font):
    ____________
    2 |. . . . . |10
    1 |. . . . |9
    FPAudio like this:
    ____________
    2 |. . . . |10
    1 |. . . . . |9
    I must admit that I haven't taken much notice... my old case with A7N8X
    Deluxe has probably exactly what you're looking for in it.
    On myy K8N Diamond there is not this functionality at all.
    > port.
    Often the BIOS has "Auto", "Disabled" as options for oinboard
    peripherals. If it detects another peripheral of th same type it will
    disable the onboard one.
    Ideally you want a back panel connecter - I've looked and not found any
    for sale, but I'm sure there must be somewhere.
    Alternatively you want a USB Game Port adaptor... I can't find any that
    support digital controllers.
    Ben
    A7N8X FAQ: www.ben.pope.name/a7n8x_faq.html
    Questions by email will likely be ignored, please use the newsgroups.
    I'm not just a number. To many, I'm known as a String...
  6. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    > missing?
    Describing it.
    The connector on the motherboard is made of 16-1 pins layed out like this:
    _______________
    1 |. . . . . . . .|15
    2 |. . . . . . . |16
    Signal names:
    1. +5V 2. +5V
    3. J1B1 4. J2B1
    5. J1CX 6. J2CX
    7. GND 8. MIDI_OUT
    9. GND 10. J2CY
    11. J1CY 12. J2B2
    13. J1B2 14. MIDI_IN
    15. +5V 16. (not present)
    As you can see it accomodates power and ground, digital signals for the two
    buttons and analog signals for the two axis' for each of the two
    controllers. The MIDI signals (I believe they are digital), originally
    intended for music I/O, are exploited by newer gamepads to support more than
    2 buttons and two axis'.
    The one above is the header connector layout. Then there is a 15-pin ribbon
    cable and finally a female game/MIDI port with 15 pins with the exact same
    functions I described above.
    > Often the BIOS has "Auto", "Disabled" as options for oinboard peripherals.
    > If it detects another peripheral of th same type it will disable the
    > onboard one.
    In this case it is called "Enabled" but I must admit it looks more like
    "Auto".
    I found some but also read about problems with newer controllers that
    exploit the MIDI signals.
    > Ben
    Thanks for help!
    Merak
  7. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    news:Vyx6e.52286$kC3.50706@tornado.fastwebnet.it...
    >> cards).
    > remain undetected until I physically unplug the card. One thing I didn't
    > check is wether there are jumpers on the card, but I remember not.
    Have you tried different PCI slots? (just a thought)
    >> headphones to 5.1. Seems amateurish to me
    The only reason I mention it is because it is a bloody nuisance. If changing
    speaker configs without rebooting can be done on an n-force board, there is
    no reason it can't be done on others, after all isn't that what plug and
    play is all about?
    Any reason you can't run some cables from the back of the machine to the
    front with some speaker jacks? IIRC when you use the front panel connectors
    on the mobo, the rear speaker connectors are disabled. (I could be wrong
    about that).
    Another thought, are there adapters around that might work? I know there are
    serial to USB adapters, maybe something similar for your needs - no
    guarantee of (compatability naturally)
    good luck.
  8. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    > play is all about?
    No plug and play is about having your hardware detected so that the OS
    can automatically install the software.
    Hot-reconfiguration is just something we're used to for many things.
    Having to reboot when you change your speaker configuration is a bit
    excessive.
    > about that).
    Usually the FPAudio connecter has jumpers on it - these jumpers connect
    the signal to the back panel connectors. When you plug the FPAudio
    connector in, you are replacing the jumpers and so the sound goes to the
    front instead.
    Ben
  9. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    Yes, tried it.
    For the most part it's a matter of convenience: I liked the idea of being
    able to plug things on the front side, mainly earphones and microphone,
    which I don't keep constantly attached.
    > IIRC when you use the front panel connectors on the mobo, the rear speaker
    > connectors are disabled. (I could be wrong about that).
    Each audio channel has two pins: forward signal and return signal (to back
    connectors). My front panel connector has a Y cable for each channel, always
    providing a path for current to the rear connectors: this way, earphones and
    speakers are usable at the same time.
    > are serial to USB adapters, maybe something similar for your needs - no
    I've searched for them and found some: however I have been told that they
    may not work with controllers with more than 2 axis / 2 buttons because
    those controllers usually exploit the MIDI functionality of the port and not
    just the analog signals of the game port.
    I've also searched for the cable that Asus claims to be "sold separatly" to
    use the onboard game port: it's supposed to be a 15-pin ribbon cable with a
    female game/MIDI port at one end and motherboard connectors at the other. I
    couldn't find it anywhere though :(
    Merak
  10. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    In article <AXO6e.53946$kC3.35807@tornado.fastwebnet.it>, "Merak"
    <me@anywhere.net> wrote:
    <<snip>>
    > Merak
    Here is an example:
    "Asus USB2.0/Game Cable"
    http://www.newegg.com/app/ViewProductDesc.asp?description=13-131-206&depa=0
    There is one pictured here, only 1.99 euro:
    http://cgi.ebay.it/ws/eBayISAPI.dll?ViewItem&category=1244&item=6757412780&rd=1&ssPageName=WD2V
    Paul
  11. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    >>missing?
    > Describing it.
    > _______________
    > Signal names:
    > 1. +5V 2. +5V
    > 3. J1B1 4. J2B1
    > 5. J1CX 6. J2CX
    > 7. GND 8. MIDI_OUT
    > 9. GND 10. J2CY
    > 11. J1CY 12. J2B2
    Hmm... thats close, but not quite what I have in the manual for my A7N8X...
    It looks like you descibed the plug, rather then the socket on my board.
    (if you get what I mean)
    I suspect somebody got their head inside out, and that really, they are
    the same. Swapping the top and bottom rows would make them the same.
    Ben
  12. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    > A7N8X...
    Sorry, my fault: I swapped the two rows in the diagram, like you suspected
    Merak
  13. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    >>A7N8X...
    Cool... then that cable on eBay should be spot on.
    Let us know how it goes!
    Ben
  14. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    newegg. Not eBay.
    Ben
  15. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    "Paul" <nospam@needed.com> wrote in message
    news:nospam-1204051002480001@192.168.1.178...
    > <<snip>>
    >> to
    >> a
    >> I
    >> Merak
    > Here is an example:
    Looks like exactly what he is after. Just hope it's not a case of throwing
    good money after bad.
  16. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    Yeah, it's exactly the item I was looking for.
    I think I'll give it a try... in the worst case I'd loose 6 euro.
  17. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    >> throwing good money after bad.
    I bought the gameport header from on eBay and it works perfectly!
    Thanks for pointing it out to me!
    Merak
  18. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    Good to hear. Thanks for letting us know your success.
    Ben
Asus Audio Sound Cards Motherboards
