G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I think I saw a post that describes a similar problem I'm experiencing, but
I didn't find the solution. When I enable q-fan option in bios and when I
boot up system cold, I get a fan error message during POST. The fan doesn't
start because the low temperature threshold hasn't been reached yet. First I
tried to lower it, but I cannot set the threshold lower than 35 C (although
the manual says I can set whatever temperature I want). I tried downloading
the new bios, disabling cool&quiet, fiddling with other power options, but
it just doesn't work. Btw, I'm using an original AMD fan and heatsink, so
that shouldn't make any problems.
So, is there any way to make it work? Although I could live with those
annoying beeps at the system boot-up, the real problem is that if CPU fan
really fails, I wouldn't know it until it'd be too late.
Thanks.
Thanks.
